hisham.i
decimal to binary |
Posted: Thu Sep 01, 2011 12:06 am |
I am reading the timer value and store it into an integer, but I want to put the first 4 bits of the integer value on port b, then after 1 sec I want to put the last 4 bits in portb.
How can I do this?
Thanks in advance. |
ezflyr
Posted: Thu Sep 01, 2011 6:23 am |
You can use 'bit masking' on the integer value to alternately look at the lower 4 bits, followed by the upper 4 bits. You would AND the original value with 0Fh to get the lower bits, and F0h to get the upper bits.
Bit shifting: http://en.wikipedia.org/wiki/Mask_%28computing%29
You don't say which PIC you are using, and whether all 8 bits of port b are available? If so, you can output the new values directly. If not, and say only 4 bits were available, the lower bits would be output directly, and the upper bits would be shifted right 4 places before being output.
John |
Posted: Thu Sep 01, 2011 7:18 am |
and of course on the PIC (available via CCS), you have the 'swap' function, which swaps the nibbles in a byte. So:
int8 timer_val;
timer_val = what_you_want;
output_b(timer_val & 0xF);
swap(timer_val);
hisham.i
Posted: Sat Sep 03, 2011 12:48 am |
Thank you
I tried your code Ttelmah and it works correctly:)
Thanks |
