Embedded ethernet kit resets
chrispol
PostPosted: Mon Mar 15, 2010 12:04 pm     Reply with quote
I seem to be getting alot of resets in MACGetHeader, has anyone else seen this or have any ideas?
   // such as if a single SPI bit error occurs while communicating or a
   // momentary power glitch could cause this to occur in rare circumstances.
   if(header.NextPacketPointer > RXSTOP || ((BYTE_VAL*)(&header.NextPacketPointer))->bits.b0 ||
      header.StatusVector.bits.Zero ||
      header.StatusVector.bits.CRCError ||
      header.StatusVector.bits.ByteCount > 1518 ||
      !header.StatusVector.bits.ReceiveOk)
      //Reset();
      printf("RESET CPU\r\n");
      reset_cpu();
PostPosted: Mon Mar 15, 2010 12:19 pm     Reply with quote
Add a printf statement (or statements) to display all those values in
the if() statement. Then you can see which one is causing the problem.
chrispol
PostPosted: Tue Mar 16, 2010 11:58 am     Reply with quote
Good idea will do
chrispol
PostPosted: Tue Mar 16, 2010 12:10 pm     Reply with quote
Last Reset = 12
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
Last Reset = 0
seems like a bit of all of them are triggering
