boraciner
18F4520 SD CARD INIT PROBLEM --WITH SD CARD ADAPTER !! |
Posted: Sat Jan 16, 2010 12:08 pm |
Hi! I'm using a sd card adapter but I cannot initialize it, I'm using 20mhz cyristal and the codes are :
Card capacity is 1gb
#include "r mmc 452.h"
#define MMC_CLK PIN_C3
#define MMC_DI PIN_C4
#define MMC_DO PIN_C5
#define MMC_CS PIN_C2
#DEFINE _CS PIN_C2
#DEFINE MAX_FILES 2 /// max number of open files
#DEFINE MMC_BUFF_SIZE 32 /// 32 for PCM
//#include <mmc_spi_rft.c>
#include <mmc_spi.c>
char data[512];
int16 i,j,k,l;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(spi_master | spi_l_to_h | spi_clk_div_64 | spi_xmit_l_to_h);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_oscillator(True);
set_tris_c(0b10010011); //c7=rx IN, c6=tx OUT, c5 SDO OUT ,c4 SDI IN
output_high(MMC_CS);
printf("I HOPE IT WILL WORK \r\r");
if(mmc_init ()!=0) printf("\r\n ERROR\r\n");
else printf("\r\n OK\r\n");
while(true)
AND the header is
Code: | #include <18F4520.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=9)
I'M WAITINg for your reply!! Thanks A LOT!!! ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
Xeno_jimmy
boraciner
Posted: Sat Jan 16, 2010 1:13 pm |
I bought it from ebay ( Gravitech )
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=390108947839&ssPageName=STRK:MEWNX:IT
Code: | This is a simple MicroSD adapter card. It allows you to interface with any microcontrollers. It is perfect for mass storage, WAV/MP3 player and data logging. The adapter breaks out the MicroSD socket to a standard 0.1" 8-pin header. It can be plug directly onto the boardboards. This adapter features innovations that set it apart from other SD card adapter. Innovations feature like on-board card detect LED, Push-Push socket, and 3.3V regulator. Which mean either 3.3V or 5.0V microcontroller can be connected directly with the board. You can even use this 3.3V to power external circuits up to 250mA.
Pinout:
VIN: Input power to the SD card (3.3V to 6.0V)
GND: Common (Connects to the housing of the SD socket)
3V3: Output voltage from the on-board 3.3V regulator (250mA)
CS: Chip select
DI: Serial input data
SCK: Serial clock
DO: Serial output data
CD: Card detect (active low)
Features:
• On-board 3.3V regulator
• Connect directly to 3.3V or 5.0V microcontroller
• Card detect LED
• Include 8-pin male header
• Board dimension: 1.4”x0.8”
I'M still waiting for any help .. ! please help me ![Rolling Eyes](images/smiles/icon_rolleyes.gif) |
boraciner
WITH A DIFFERENT PIC.. |
Posted: Sat Jan 16, 2010 1:38 pm |
I used 18F452 and I made the circuit in isis file and the codes.. but
the output doesn't come the same.. !!
my output like this:
Hadi hayirlisi UMARIM CALISIR
cmd1cmd1cmd1cmd1cmd1cmd1cmd1cmd1cmd1cmd1Gelen Cevap: 11
HEX olarak okunan datalar CHAR olarak okunan datalar
04 20 00 00 00 0A 00 00 00 0A 04 00 00 02 00 00 D € 0 00 00 00 02 00 00 00 00 00 0 00 00 00 00 14 10 1 00 04 C0 00 00 40 06 01 40 00 00 08 00 00 00 00 00 00 00 01 00 0C 00 00 00 00 08 80 08 00 A0 00 00 00 80 80 18 00 56 00 00 00 01 84 00 00 06 00 80 80 00 00 00 60 00 00 00 00 00 00 40 00 00 20 00 40 00
06 00 82 00 04 20 20 00 00 00 01 08 10 00 00 00 À @ 4 0 20 80 00 ˆ 08 00 00 00 00 1 02 00 00 08 00 00 00 00 00 01 00 80 |
the source codes and isis file
www.dreamrobotics.com/mmc.rar |
Posted: Sat Jan 16, 2010 2:41 pm |
What is the Vdd voltage on the PIC, and what is the Vin voltage on the
SD/MMC adapter card ?
Also, what's the purpose of setting the #use rs232() to 9 bits ?
The standard is 8 data bits. |
Posted: Sat Jan 16, 2010 3:21 pm |
there is a 5 to 3.3V voltage regulator on this card adapter. and I think that the 9 bits is not a problem 'cause the string that I wrote message to inform me via serial port does work.. |
Posted: Sat Jan 16, 2010 3:26 pm |
To repeat:
1. What is the Vdd voltage on the PIC ?
2. What is the Vin voltage on the SD/MMC adapter card ? |
Posted: Sat Jan 16, 2010 4:17 pm |
Vcc is 5V its connected pic and sd adapter. Sd adapter regulates this voltage to 3.3 V in itself.So, I don't have to connect 3.3V externally to the SD card adapter |
Posted: Sat Jan 16, 2010 4:34 pm |
According to the MicroSD adapter schematic, it has an on-board voltage
regulator that converts the +5v input down to +3.3v. Every chip on
the board runs off +3.3v.
http://gravitech.us/MicroResearch/Others/MICROSD-ADP/MicroSD-ADP_Schematic.pdf
The schematic also shows that the Data Out pin "DO" on the SD card
connects directly to the header. This means that the "DO" signal going
to the PIC has voltage levels of +3.3v and ground.
However, your PIC is running at +5v. In the 18F4520 data sheet,
in the Overview section, it says that the PIC's SDI pin has a Schmitt
Trigger input "ST". In the Electrical Characteristics section, it says
that the "Input High Voltage" "Vih", must be at least 0.8 x Vdd.
In your case, with a +5v Vdd, the Vih must be at least 4.0v, but your
Micro-SD adapter only puts out 3.3v max as the Vih. Therefore it won't
work. |
Posted: Sat Jan 16, 2010 4:41 pm |
owww.. you're the Master!
Sir, now... how can I supply that voltage level?
Can I take 3.3V from the adapter in any way? |
Posted: Sat Jan 16, 2010 4:44 pm |
If I apply a resistor ,can I decrease the voltage level? |
boraciner
Posted: Sat Jan 16, 2010 4:48 pm |
there is a voltage regulator on the board. so, I can directly connect the 5V then It works .
I also talked with the seller about it ,he says that I don't have to supply 3.3v |
Posted: Sat Jan 16, 2010 4:49 pm |
What type of 18F4520 PIC do you have ? Do you have the normal "F"
version or do you have the 18LF4520 ? Look at the top of the
chip and see. If you have the LF version, you could run the PIC at +3.3v.
It would work with the MicroSD adapter. The only other problem would
be the serial port connection to the PIC. It would have to work with
the +3.3v cmos levels to/from the PIC.
-or-
Do you have any logic gate chips available in the "HCT" or "ACT", etc.,
families ? Something like 74HCT125A, or 74HCT08, or even 74HCT04 ?
If you so, you could run that chip at +5v, and use it as a level translator.
You could put the MicroSD's +3.3v SDO signal into it and you would get
+5v cmos levels as the output. This +5v cmos SDO signal could then go
to the PIC's SDI pin. Then it would work.
If you use the 74HCT04, you would need to put two gates in series, so
there would be no inversion, overall. |
boraciner
Posted: Sat Jan 16, 2010 4:56 pm |
It's a property of this board.. my seller said
Code: | Dear boraciner,
Just the 5V is enough. There is an on-board 3.3V regulator so you don't need to supply 3.3V.
Tony
Posted: Sat Jan 16, 2010 5:19 pm |
Your MicroSD board runs at +3.3v. We already established that.
The problem is that the PIC (running at +5v) requires at least a 0 to 4v
signal coming into its SDI pin. Your MicroSD board only puts out 0 to
3.3v.
Therefore, a level translator is needed between the MicroSD board and
the PIC for that one signal.
I suggest that you order a 74HCT125 chip and use it as a level translator. |
