evaradharaj
PIC reset |
Posted: Mon Mar 08, 2010 12:50 am |
Hai,
I am using PIC16f877a. It is often resetting. I am not using WDT. I checked that, it is not enabled. But the problem continues....
I am using ADC using LM324 IC.
My code is like this,
printf("welcome");
printf(adc Value);
output:
wel wel wel.... if I press the IC then, the output is welcome welcome....sometimes the adc value.....
What is the problem sir? _________________ embedding innovation in engineers |
John P
Posted: Mon Mar 08, 2010 10:54 am |
Is your chip in low-voltage programming mode, and what have you done with PortB.3? I'd pull the reset high with a resistor too, just to be on the safe side. |
evaradharaj
reset |
Posted: Mon Mar 08, 2010 11:19 pm |
Thanks for your replies......
Yes, I am using Low voltage programming mode. That pin is left free.
I am having +5 v supply which is having 7805 and 1000uf from input and 22uf in the output sides.
Is that any problem....
The pullup resistor is connected to the MCLR pin.
I am using max232 board also.
What is the best way to save my pic? _________________ embedding innovation in engineers |
Wayne_
Posted: Tue Mar 09, 2010 2:59 am |
I would go with hardware fault, dry joint, bad connection etc.
BUT what is this line suppose to be ? printf(adc Value); ?
Where is adc and Value defined and what are they set to ?
What are your fuse settings ?
Does it work if you just touch the pins of the device or do you have to put pressure on to it to push it down ?
Are you using a bread board, surface mount etc ? |
evaradharaj
soldering |
Posted: Tue Mar 09, 2010 4:45 am |
I am using dot board soldering.. my fuse settings are NOWDT,XT,NOPUT,NOBROWNOUT,LVP
when i press on the pic microcontroller near top and bottom (at a time ) it is working(the printf statement on the terminal is coming).. other times its not working... many times its coming as "welcome" only _________________ embedding innovation in engineers |
John P
Posted: Tue Mar 09, 2010 7:29 am |
"Yes, I am using Low voltage programming mode. That pin [RB3] is left free."
Sigh.
: RB3 should not be allowed to float if LVP
is enabled. An external pull-down device
should be used to default the device to
normal operating mode. If RB3 floats
high, the PIC16F87XA device will enter
Programming mode.
evaradharaj
RB3 |
Posted: Tue Mar 09, 2010 10:11 pm |
I have used more than 100 boards with RB3 left free...
But they have worked perfectly for some days...
After that they will not work.....
Is RB3 free the problem? _________________ embedding innovation in engineers |
John P
Posted: Wed Mar 10, 2010 3:13 pm |
So, you tried tying pin RB.3 low, and what happened? |
