dneale
Joined: 25 Nov 2009 Posts: 9 Location: Albuquerque NM
PCD: Changing SPI Clock with #use SPI |
Posted: Tue Mar 09, 2010 4:24 pm |
I am interfacing an AD7367 ADC to a 24FJ128GA006. I have the code working but I'm getting way too much noise. Its on a breadboard so that is some of it but I want to check if some of it is in the SPI sampling so I need to slow the clock since #use SPI sets the fastest clock. I cannot seem to get the SPICON1 clock bits to change.
I'm running PCD & IDE version 4.105 with a CCS PIC 24 Demo board.
Thanks for your help.
Dave
Code: | #include "C:\Program Files\PICC\24F Exercises\A2D Test7.h"
#include <stdio.h>
#use rs232(UART1, DEBUGGER)
#use spi(SPI1, MASTER, MODE=3, BITS=32, STREAM=A2D_Data)
#use fast_io(D)
//SPI chip select and conversion start pins
#define AD7367_nCS PIN_D0
#define AD7367_nCNVST PIN_D1
#bit SPI_EN = 240.15
#bit SPI_DIV_64 = 242.0
#bit SPI_DIV_16 = 242.1
/* Print n as a binary number */
void printbitssimple(int n) {
unsigned int i;
i = 1<<(sizeof(n) * 8 - 1);
while (i > 0) {
if (n & i)
printf("1");
printf("0");
i >>= 1;
int32 A2D_Result;
int16 ADC_A_RES, ADC_B_RES, Dummy;
int8 k=0,n=11;
set_tris_D(0x00);
SPI_EN = 0;
SPI_DIV_64 = 0;
SPI_DIV_16 = 0;
SPI_EN = 1;
while(k < n )
output_low(AD7367_nCNVST);//Pulse to conversion start
output_high(AD7367_nCNVST);
output_low(AD7367_nCS);//Enable the data line of the A2D
ADC_A_RES = spi_xfer(A2D_Data,Dummy,16);//read the results
ADC_A_RES = ADC_A_RES>>2;
ADC_B_RES = spi_xfer(A2D_Data,Dummy,16);
ADC_B_RES = shift_right(&ADC_B_RES,2,0);
output_high(AD7367_nCS);//Tristate the data line
printbitssimple(ADC_A_RES);
printf("\n\r");
delay_ms(1);
k++;
}//end while
A2D Test7.h
Code: | #include<24FJ128GA006.h>
#FUSES NOJTAG //JTAG disabled
#FUSES ICSP2 //ICD uses PGC2/PGD2 pins
#FUSES NOWINDIS //Watch Dog Timer in Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES FRC_PS //Fast RC Oscillator with Post Scaler
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO //OSC2 is clock output
#FUSES NOPR //Pimary oscillaotr disabled
#device ICD=TRUE
#fuses HS,PR
#use DELAY (CLOCK=20000000) |
_________________ Dave N |
Posted: Tue Mar 09, 2010 8:19 pm |
According to the PCD manual, you can use the BAUD parameter in your
#use spi() statement to set the SCLK speed:
Quote: |
#USE SPI
Syntax: #use spi (options)
BAUD=n Target bits per second. Default is as fast as possible.
Add the parameter shown in bold below. Fill in the desired baud rate.
Quote: |
#use spi(SPI1, MASTER, MODE=3, BITS=32, BAUD=xxxxx, STREAM=A2D_Data)
The compiler will try to get as close as possible to your desired baud
rate, based on the limitations of the SPI module's baud rate generator. |
dneale
Posted: Wed Mar 10, 2010 5:27 pm |
Thanks so much. My Nov 2009 manual strikes doesn't have that option. I see there is a newer one. I'll have to download it.
Thanks.
Dave _________________ Dave N |
