Using USB and an EEPROM to create a memory stick (& keyb
JamesW,Rochester,UK
PostPosted: Wed Mar 03, 2010 10:57 am     Reply with quote
Hi folks,
I don't know if anyone can offer any pointers here.
I am trying to make my own memory card using a pic and a 512KB eeprom. Is this possible?
What I need to do is create a usb device that has a singe button on it, that when pressed runs a very small executable program from the memory card.
Thoughts were to incorporate a keyboard HID and a mass storage device, but I'm not really sure if this is the right way to go about it.
Thanks in advance
James
FvM
PostPosted: Wed Mar 03, 2010 1:54 pm     Reply with quote
The device should implement the mass storage device class, if it's
intended to be written as a memory, but I don't see a purpose for HID.
If a dedicated PC application is providing the device interface,
you can use any USB device class of your choice.
JamesW, Rochester, UK
PostPosted: Mon Mar 08, 2010 4:14 am     Reply with quote
Thanks for the tip.
What do I do with regards to a file system on it? Can I just allow access to the eeprom, or do i need to be a bit more sophisticated?
Cheers
James
FvM
PostPosted: Mon Mar 08, 2010 12:16 pm     Reply with quote
Mass storage device class uses a logical block addressing with 512 Byte blocks for small memory. File system
handling is done on the PC side. But you may want to preformat the file system and create fixed entries in the
FAT and root directory for files controlled by your application.
