Command line for dsPIC33F
mihir
PostPosted: Fri Feb 26, 2010 6:49 pm     Reply with quote
I am trying to use the command line compilation for the PCD compiler
with ccsc +FD filename.c and it compiles the code.
But if I use +EA or +EW it is supposed to show errors and warnings, but it does not show them. But it does compile the code.
I am using command prompt for doing this.
Can anyone help?
Also, I am able to download the code into the chip with the CCSLOAD command-line.
