Source code PICDEM2Plus
MegatroniC
View user's profile Send private message ICQ Number
PostPosted: Wed Feb 24, 2010 2:42 am     Reply with quote
Could you tell me, can be found in C source code of a demo board PICDEM 2 PLUS.
I searched through the forum but could not find anything.
Thank you,
Greetings!
PostPosted: Wed Feb 24, 2010 1:28 pm     Reply with quote
PICDEM 2 PLUS. I searched through the forum but could not find anything.
Which version of the PicDem2-Plus board do you have ?
Does it look exactly like this one ?
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en010072
That's the original version.
Or does it look like this one ?
http://www.microchipdirect.com/ProductSearch.aspx?Keywords=DM163022
That's the new "Rohs" version.
The Flex LCD driver has a different setup (pins and power control)
if you are using the "Rohs" version. The setup is documented int
the link below.
Flexible LCD driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Blink an LED on pin B0:
http://www.ccsinfo.com/forum/viewtopic.php?t=23106&start=4
A/D converter test:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
Use A/D input to control PWM duty cycle:
http://www.ccsinfo.com/forum/viewtopic.php?t=40007&start=1
Simple test of 24LC256 eeprom:
http://www.ccsinfo.com/forum/viewtopic.php?t=23824&start=1
Find addresses of all i2c slave devices on the board:
http://www.ccsinfo.com/forum/viewtopic.php?t=37650&start=6
There are many more examples on the forum.
MegatroniC
PostPosted: Thu Feb 25, 2010 1:12 am     Reply with quote
Thanks for the response and attention.
PICDEM2 plus that I have is like this.
http://farm4.static.flickr.com/3407/3345855679_12ceb45baa.jpg
For now move from assembler to C, trying to do with control buttons and menu similar to that in the demo board.
Somewhere I could do something, but I'm curious to see how it is implemented there. Smile
PostPosted: Thu Feb 25, 2010 1:16 am     Reply with quote
That's the original board. That's the one that I have. The demo
programs that I've posted on the forum will work with that board.
