External Oscillator frequency for 16f689
yrb
PostPosted: Mon Feb 22, 2010 3:42 am     Reply with quote
Hi
I would like to know if 16f689 supports external Oscillator frequency
6 MHz for external Oscillator frequency 4Mhz to be used in function:
setup_oscillator(OSC_4MHZ, OSC_NORMAL);
Is it right ?
yrb
PostPosted: Mon Feb 22, 2010 1:22 pm     Reply with quote
The setup_oscillator() function is used for the internal oscillator,
not external. The internal oscillator supports 4 MHz and 8 MHz, and
other frequencies but not 6 MHz. If you want 6 MHz, then use an
external crystal (with 22pf capacitors) and use HS in the #fuses.
Don't use setup_oscillator() for an external crystal.
