how to call a function in main
techy_yake
PostPosted: Tue Feb 23, 2010 7:29 am     Reply with quote
Hi everyone. Hope you guys can help me here. I worked with RTC DS1307 and its working fine but when I get to call a function in the void main, my RTC won't tickle anymore.
Here is my sample code:
   //enable_interrupts(GLOBAL);
   port_b_pullups(TRUE);
   kbd_init();
   gca_ds1307_regs[DS1307_SECONDS_REG] = 30; // 30 seconds
   gca_ds1307_regs[DS1307_MINUTES_REG] = 59; // 59 minutes
   gca_ds1307_regs[DS1307_HOURS_REG] = 23; // 11 PM
  //gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG]= 0; // Skip this.
   gca_ds1307_regs[DS1307_DATE_REG] = 22; // 22th
   gca_ds1307_regs[DS1307_MONTH_REG] = 02; // February
   gca_ds1307_regs[DS1307_YEAR_REG] = 10; // 2010
   ds1307_set_date_time();
   ds1307_read_date_time();
   // Get these into variables with shorter names, so I can
   // put them into printf more easily.
   sec = gca_ds1307_regs[DS1307_SECONDS_REG];
   min = gca_ds1307_regs[DS1307_MINUTES_REG];
   hrs = gca_ds1307_regs[DS1307_HOURS_REG];
   day = gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG];
   date = gca_ds1307_regs[DS1307_DATE_REG];
   month = gca_ds1307_regs[DS1307_MONTH_REG];
   yr = gca_ds1307_regs[DS1307_YEAR_REG];
   printf(lcd_putc, "\n\%02d:\%02d:\%02d", hrs,min,sec);
    room_controller();
  //disable_interrupts(GLOBAL);
Here is the function i am to call:
//           room controller                 //
void room_controller(void)
   lcd_gotoxy(1,2);
   printf(lcd_putc, "PERSONS:%d    ", persons);
            if(input(SENS_IN)){
               while(input(SENS_IN));
               while(!input(SENS_OUT));
               while(input(SENS_OUT));
                persons++;
                OUTPUT_HIGH(DEVICE);
                lcd_gotoxy(1,2);
                delay_ms(600);
             else if(input(SENS_OUT))
                 while(!input(SENS_IN));
                if(persons>0){
                   persons--;
                   lcd_gotoxy(1,2);
                   delay_ms(600);}
                else if(persons==0){
                  OUTPUT_LOW(DEVICE);
                  lcd_gotoxy(1,2);
                  delay_ms(600);}
How can I call other function without interrupting my RTC?
thanks in advance!!!
collink
PostPosted: Tue Feb 23, 2010 8:23 am     Reply with quote
Well, your problem is that the function you are calling has an infinite while loop in it. Control never returns to main. There are a variety of ways of fixing it but since main also has a while loop you might start by just taking the while loop out of the called function and let main call that function repeatedly.
