I have a piece of code written in assembly to drive the sed1335. It took me close to two weeks to get a working driver for this chip.
Now I'm running into problem in different area, trying different software to see if I can go faster to reach my goal.
Any idea why ?
I have modified the sed1335 to match my hardware, even when I turn on a single pixel like "glcd_pixel(40,40,1);" it will turn on two pixels next to each other.
I have checked and rechecked the code. I don't see any difference in my modified code other than the control port and the display width.
Can you help.
Dezso:
Dezso Guest
Posted: Fri Feb 19, 2010 10:50 pm
Got it working.
I have always been a ASM guy, just learning C.
// Purpose: Read a byte of data
// Outputs: The byte of data
int8 glcd_readByte()
byte data;
set_tris_d(0xFF);
output_high(GLCD_A0);
output_high(GLCD_WR);
output_low(GLCD_CS);
delay_cycles(2);
output_low(GLCD_RD);
delay_cycles(2);
data = input_d();
delay_cycles(5);
output_high(GLCD_RD);
output_high(GLCD_CS);
set_tris_d(0x00);
return data;
