		| Author | Message |
		| Sensor
				| I2C Communication Problem using PIC16F877A |
				|  Posted: Wed May 31, 2006 10:14 am |   |
				| Compiler: PCWH version 3.236 PIC = PIC16F877A
 Voltage = 5V
 Osc Speed = 4MHz
 I am trying to comminicate with a HMC6352 compass by Honeywell.  I have my PIC16F877A configured as the master.  I'm just trying to read the heading output from the compass.  No matter what I try, heading_a and heading_b are always 255.  Also, if I don't have the "Force_HW" in the #use i2c(...) in the *.h file, then my i2c clock is only 37khz.  If I put the Force_HW in, then my i2c clock is 100khz.  Below is a link to the compass datasheet and my code.
 http://www.ssec.honeywell.com/magnetic/datasheets/HMC6352.pdf
  	  | Code: |  	  | /***** Start of HMC6352.h *****/
 #include <16F877A.h>
 #device adc=8
 #FUSES NOWDT                    //No Watch Dog Timer
 #FUSES XT
 #FUSES NOPUT                    //No Power Up Timer
 #FUSES NOPROTECT                //Code not protected from reading
 #FUSES NODEBUG                  //No Debug mode for ICD
 #FUSES NOLVP                    //No low voltage prgming
 #FUSES NOCPD                    //No EE protection
 #FUSES NOWRT                    //Program memory not write protected
 #use i2c(Master,sda=PIN_C4,scl=PIN_C3,Force_HW)
 /***** End of HMC6352.h *****/
 /***** Start of HMC6352.c *****/
 #include "HMC6352.h"
 #include "lcd_driver.c"
 int heading_a;
 int heading_b;
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 setup_psp(PSP_DISABLED);
 setup_timer_1(T1_DISABLED);
 setup_vref(FALSE);
 heading_a = 0;
 heading_b = 0;
 i2c_start();
 i2c_write(0x43);   //slave address of HMC6352
 i2c_write('A');   //have also tried i2c_write(0x41);
 //i've tried with and without the delay
 delay_ms(6);   //requires 6mS before data is ready to be read
 heading_a = i2c_read();
 heading_b = i2c_read();
 i2c_stop();
 lcd_clear();
 lcd_putch("Heading:");
 lcd_XY(2,0);
 printf(lcd_putch, "%u, %u", heading_a, heading_b);
 delay_ms(3000);
 /***** End of HMC6352.c *****/
		| PCM programmer
				|  Posted: Wed May 31, 2006 1:10 pm |   |
				| I read the data sheet and the appnote.  They don't really have a very good explanation of the i2c operations required to talk to the chip.
 But as far as I can tell, the test program shown below has a chance to
 work.     They don't show a NAK on the last i2c read, but I've added it
 below, because that's the standard way of doing things.
  	  | Code: |  	  | #include <16F877A.H> #fuses XT, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
 #use i2c(Master, sda=PIN_C4, scl=PIN_C3, FORCE_HW)
 #define HMC6352_I2C_WRITE_ADDRESS 0x42
 #define HMC6352_I2C_READ_ADDRESS  0x43
 #define HMC6352_GET_DATA_COMMAND 0x41
 // Read the compass heading.  This is in units
 // of 1/10's of a degree, from 0 to 3599.
 int16 HMC6352_read_heading(void)
 int8 lsb;
 int8 msb;
 i2c_start();
 i2c_write(HMC6352_I2C_WRITE_ADDRESS);
 i2c_write(HMC6352_GET_DATA_COMMAND);
 i2c_stop();
 delay_ms(7);  // Allow 1 ms extra for safety
 i2c_start();
 i2c_write(HMC6352_I2C_READ_ADDRESS);
 msb = i2c_read();
 lsb = i2c_read(0);
 i2c_stop();
 return((int16)msb | ((int16)lsb << 8));
 int16 heading;
 heading = HMC6352_read_heading();
 printf("Heading in degrees = %lu\n\r", heading/10);
		| rnielsen
				|  Posted: Wed May 31, 2006 1:37 pm |   |
				| Yes, the spec sheet really is written quite poorly.  It's hard to understand just how to talk to the sensor.
 One thing that could help is the fact that i2c_write() returns the ACK bit.  You could write your routine to let you know if the part is responding properly.  If it's not, it could be giving you the result of 255.  Try something like this:
 i2c_start();
 if(i2c_write(address))
 puts("NO ACK");// sensor did not ack back
 // put the rest of the code in here to talk to the sensor
 i2c_stop();
 or something like that.  This will let you know if the sensor is acknowledging the Master's signals.
 Make sure you have pullups on each line, too.  Between 2K - 4.7K.
 Ronald
		| Sensor
				|  Posted: Thu Jun 01, 2006 8:16 am |   |
				| I think something is wrong with my I2C bus.  Whether, I have the compass plugged in or not, the bus acts the exact same.  I always get a NACK on the 9th clock pulse.  I double checked, I have the pin 42 of the PIC going to the SDA line on the compass (pin 7) and I have pin 37 of the PIC going to the CLK line on the compass (pin 10).  I've got 3k pullups on each of those lines.  Why does the bus act the exact same whether the compass is plugged in or not? |  |
		| rnielsen
				|  Posted: Thu Jun 01, 2006 9:21 am |   |
				| That probably means that the sensor is not 'talking' to the Master.  If you have a scope hooked up to the SDA and SCL lines  you will notice that the 9th clock pulse is the ACK/NACK pulse.  If the SDA line is High during the 9th clock pulse then the sensor is not talking.  If the sensor is out of the circuit then the SDA line will be held High by the pull up resistor.  This will give you a value of 255 ( all bits high) and the ACK pulse will be high also, causing a NOACK.  Try puting the sensor in place and then only send an i2c_start(), i2c_write(address) and then an i2c_stop().  Put delays between each command.  This will let you know if the sensor can detect it's own address.  Monitor the ACK pulse to see if the sensor actually responded to the address call.  If it doesn't, then you might not be sending the correct address to the sensor.  Make sure the sensor's address is configured correctly and the Master is sending the same address.
 It could be possible that the sensor is dead too.
 Ronald
		| Sensor
				|  Posted: Thu Jun 01, 2006 1:24 pm |   |
				| I placed some other device on the bus and was able to talk to them so I know my I2C bus is working.  So, I then sent only i2c_start(), i2c_write(address) and i2c_stop() and monitored the lines on the oscilloscope.  I wrote the code to try every address between 00 and FF.  Each time through the loop I would increment the address and delay so I could see what was happening on the oscilloscope.  I left the compass and one more device on the bus.  The other device has an address of 40.  When I ran the program, I would only see an ACK pulse when the address of 40 was sent on the bus.  The compass never responded to any address.  I have tried multiple compasses and they all behave the same.  I am now waiting on an engineer from Honeywell to get back to me. |  |
		| Sensor
				|  Posted: Mon Jun 12, 2006 1:11 pm |   |
				| I just received two new compasses from Honeywell and they work fine.  The two that I received before were from a "bad batch".  Thanks for all the help. |  |
		| charlie Guest
				|  Posted: Sat Dec 09, 2006 11:07 pm |   |
				| I'm not a cracker-jack programmer, but I got the code PIC Programmer posted to work by changing the return line of the HMC6352_read_heading function to the following:
 return((int16)lsb | ((int16)msb << 8));
 Just in case other people come on this thread...
 The i2c part of the code works great. Thanks for posting it.
		| lost Guest
				|  Posted: Sat Dec 30, 2006 12:12 pm |   |
				| can anyone help me to convert the program code for hmc6352 to assembly language?? |  |
		| PCM programmer
				|  Posted: Sat Dec 30, 2006 1:11 pm |   |
				| If you're lost, your first resources should be the forum's search page or http://www.google.com
 To find an assembly language program, go to Google and type in
 the name of the chip and a very common ASM instruction.
 For example, to find PIC assembly language for the HMC6352,
 use these keywords:   HMC6352  MOVLW
 I did that and got one hit.   It's Mr. Wilkinson's page, which has
 sample code on it.   I don't know if it works, but there's a lot of it.
 Then just edit the URL a little, refresh, and you get his homepage,
 which is a large project page dedicated to the HMC6352 with
 several levels of test code.
		| lost Guest
				|  Posted: Sat Dec 30, 2006 1:22 pm |   |
				| currently i'm doing the program code for hmc6352 in assembly language. but i cant make it... so i'm lost .... |  |
		| PCM programmer
		| lost Guest
				|  Posted: Sun Dec 31, 2006 4:15 am |   |
				| it really helps me alot... thanks... |  |
		| almost Guest
				|  Posted: Thu Jan 04, 2007 2:25 pm |   |
				| how can i get a proper hmc6352 code that send out the heading through rs232?? how can i edit from this soucr code??
 title "PIC16F877A Honeywell communication"
 list p = 16F877A
 include "P16F877A.inc"	; This “header file” contains all
 ; the PIC16F876A special function
 ; register names and addresses.
 ;define input/output pins_____________________________________________________________________
 #define	UNA		PORTB,0				;define unused pin
 #define SDA		PORTB,1				;define SDA in pin 1
 #define SCL		PORTB,2				;define SCL in pin 2
 #define ACK		PORTB,3				;define ACK in pin 3
 #define SYN		PORTB,4				;define SYN in pin 4
 #define	HED		PORTB,5				;define HED in pin 5
 #define UNB		PORTB,6				;define unused pin
 #define UNC		PORTB,7				;define unused pin
 ;define variables and locations_______________________________________________________________
 HEAD_LO		equ 	0x20			;8 LSB's of heading
 HEAD_HI		equ 	0x21			;8 MSB's of heading
 COUNT		equ 	0x22			;COUNT 1 used for Byte output
 COUNTB		equ		0x23
 COUNTC		equ		0x24
 DATA_O		equ		0x25			;Data to output
 IN_BIT		equ		0x26			;used to read single bits
 DATA_I		equ		0x27			;containsd input byte words
 org 	0
 goto 	START
 ;long pause (1s), used to allow for startup time______________________________________________
 LONGWAIT	movlw	0x49			;W = 49
 movwf	COUNT			;COUNT = d'73'
 LPB			movlw	0xFF			;W = FF
 movwf   COUNTB			;COUNTB = d'255'
 LPA			call 	PAUSE			;54us pause
 decfsz	COUNTB
 goto	LPA
 decfsz	COUNT
 goto	LPB
 retlw	0
 PAUSE		clrf	TMR2				;reset timer 2
 movlw	0x00				;w = F2
 movwf	TMR2				;TMR2 = FA
 bcf		PIR1, TMR2IF		;clear timeout flag
 bsf		T2CON, TMR2ON		;timer 2 on
 WAIT_LOOPA	btfss	PIR1, TMR2IF	;test timeout flag
 goto	WAIT_LOOPA		;loop until timeout flag
 bcf		T2CON, TMR2ON		;timer 2 off
 retlw	0
 ;5.4us pause, used for clock timing___________________________________________________________
 CLKWAIT		clrf	TMR2				;reset timer 2
 movlw	0xF2				;w = F2
 WAIT_LOOPB	btfss	PIR1, TMR2IF		;test timeout flag
 goto	WAIT_LOOPB			;loop until timeout flag
 retlw	0
 ;2.6us pause, used for reading bits___________________________________________________________
 BITWAIT		clrf	TMR2				;reset timer 2
 movlw	0xFC				;w = FA
 WAIT_LOOPC	btfss	PIR1, TMR2IF		;test timeout flag
 goto	WAIT_LOOPC			;loop until timeout flag
 retlw	0
 ;PORT B for SDA output________________________________________________________________________
 PORTB_OUT	bsf 	STATUS, 5		;now in bank 1
 clrf	TRISB			;All port B is now an output
 bcf 	STATUS, 5		;now in bank 0
 retlw 	0				;return
 ;PORT B for SDA input_________________________________________________________________________
 PORTB_IN	bsf 	STATUS, 5		;now in bank 1
 movlw	0x02			;W=02
 movwf	TRISB			;SDA input, rest output
 retlw 	0				;return
 ;start sequence	(SHOULD START SDA = 1, SCL = 1 'free')________________________________________
 ;_______________(ENDS SDA = 0, SCL = 0)_______________________________________________________
 ;a start sequence is represented by:
 ;1) SDA GOES HIGH (if not allready, but should be as released at end of STOP)
 ;2) HOLD SCL HIGH (if not allready, but shopld be as set at end of STOP)
 ;3) MAKE PORT OUTPUT
 ;4) WAIT 5 MICROSECONDS
 ;5) PULL SDA LOW (this signifies START)
 ;6) WAIT 5 MICROSECONDS
 ;7) PULL SCL LOW
 START_SEQ	bcf		SCL
 bcf		SDA
 call	PORTB_OUT		;make port 3 output keeping both lines high
 bsf		SDA		;SDA goes high
 bsf		SCL		;SCL goes high
 call 	CLKWAIT			;5us wait
 bcf		SDA		;SDA low while SCL high = start
 bcf		SCL		;SCL goes low (SDA still low)
 retlw	0				;return
 ;stop sequence (SHOULD START SDA = BIT, SCL =)________________________________________________
 ;______________(ENDS SDA = 1, SCL = 1)________________________________________________________
 ;a stop seqeunce is represented by:
 ;1) SDA GOES LOW (if not allready)
 ;2) WAIT 5 MICROSECONDS
 ;3) SCL HIGH
 ;5) SDA HIGH (this signifies STOP)
 ;7) MAKE PORT INPUT THEREFORE RELEASING SDA
 STOP_SEQ	bcf		SDA		;SDA goes low
 bsf		SDA		;SDA high while SCL high = stop
 call	CLKWAIT			;wait 5us
 call	PORTB_IN		;make port 3 input therefore release
 retlw 	0			;return
 ;send a byte of data and get ACK (STARTS SDA = X, SCL = 0)____________________________________
 ;________________________________(ENDS SDA = LSB, SCL = 0)____________________________________
 BYTE_OUT		movlw 	0x08			;initialise Counter
 movwf	COUNT			;COUNT = 8
 BYTE_OUT_LOOP	call 	BIT_OUT			;output bit
 decfsz 	COUNT, f		;Decrement count + test
 goto	BYTE_OUT_LOOP		;get next bit
 call	PORTB_IN		;make port 3 input to get ACK
 ;get the (N)ACK
 call	BIT_IN			;get ack bit
 bcf		ACK		;assume ACK and output on ACK flag pin (note on port 2)
 btfsc	IN_BIT, 0		;test successfull ACK (test LSB IN_BIT, ACK = 0)
 bsf		ACK		;NACK detected and output
 call	PORTB_OUT		;make port 3 an output again
 retlw	0			;return to main code
 ;read in a single bit of data for (N)ACK (STARTS SDA = N(ACK), SCL = 0)_______________________
 ;________________________________________(ENDS SDA = X, SCL = 0)______________________________
 BIT_IN		movlw	0x01			;w = 00000001
 movwf	IN_BIT			;set LSB of IN_BIT = 00000001
 bsf		SCL		;SCL high
 call	BITWAIT			;2.5us wait
 movlw	0x00			;w = 00000000
 btfss	SDA		;test to see if data is 1
 clrf	IN_BIT			;assumption wrong IN_BIT = 00000000
 bcf		SCL		;SCL low
 retlw	0			;return
 ;send a single bit of data____________________________________________________________________
 BIT_OUT		btfss	DATA_O, 7		;test MSB of data to output,this is shifted each cycle
 goto	BIT_OUT_LOW		;bit is 0
 bsf		SDA			;data bit is 1
 bsf		SCL		;clock goes high
 bcf		SCL		;clock goes low
 rlf		DATA_O, f		;shift data in DATA_O
 retlw	0			;return
 BIT_OUT_LOW	bcf		SDA		;data bit is 0
 retlw	0			;return
 ;read in a byte of data (STARTS SDA = BIT, SCL = 0)___________________________________________
 ;_______________________(ENDS SDA = 0 (ACK), SCL = 0)_________________________________________
 BYTE_IN		call	PORTB_IN		;make PORT 3 an input
 clrf	DATA_I			;clear data input register
 BYTE_IN_LOOP	call 	BIT_IN_B		;read in single bit
 decfsz	COUNT, f		;decrement and test COUNT
 goto	BYTE_IN_LOOP		;process next bit
 ;send ACK
 call	PORTB_OUT		;make PORT 3 an output
 bcf		SDA		;pull SDA low for ACK
 retlw	0				;return
 ;read in a single bit and amend to byte_______________________________________________________
 BIT_IN_B	movlw 	0x01			;w = 00000001
 movwf	IN_BIT			;IN_BIT = 00000001, i.e. assume bit is 1
 rlf		DATA_I, f		;shift data in DATA_I left (more signinifcant)
 bsf		SCL		;SCL high
 clrf	IN_BIT			;assumption wrong, IN_BIT = 00000000 as data is 0
 bcf		SCL		;SCL low
 movlw	IN_BIT			;W:LSB = data: 00000000 or 00000001
 iorwf	DATA_I, 1		;inclusive or IN_BIT and DATA_I to amend data word
 retlw	0				;return
 ;start of program_____________________________________________________________________________
 ;_____________________________________________________________________________________________
 START	bcf 	STATUS,6			;move to bank 0
 bcf		STATUS,5
 bcf		INTCON, GIE		;disable interupts at this time
 ;initialise Values
 clrf 	HEAD_LO			;clear register
 clrf 	HEAD_HI			;clear register
 bcf		UNA		;clear all output pins
 bcf		SDA
 bcf		SCL
 bcf		ACK
 bcf		SYN
 bcf		HED
 bcf		UNB
 bcf		UNC
 ;Setup Honeywell HMC6352 to be in continuous Mode 5Hz at startup
 ;with periodic reset pulses. In comments Chip will be refered to
 ;as HMC.
 call	BITWAIT
 call	CLKWAIT
 call	LONGWAIT		;long wait for startup
 movlw	0x42			;Put write address into W
 movwf	DATA_O			;Set as data out
 call	START_SEQ		;Initiate start sequnce
 call	BYTE_OUT		;send address + get ACK
 movlw	0x47			;write to RAM command
 movwf	DATA_O			;set as data out
 call	BYTE_OUT		;send data + get ACK
 movlw	0x74			;RAM memory location
 movlw	0x32			;Operational mode setup
 call	STOP_SEQ		;initialise stop sequence
 call 	LONGWAIT		;give HMC time to perform command
 ;Copy operational mode into EEPROM so it becomes the default
 ;mode of operation
 call	START_SEQ		;initialise start sequence
 movlw	0x4C			;command to write OP mode to EEPROM
 call	BYTE_OUT		;send command + get ACK
 ;Section of code that reads data from HMC
 HEADING_IN	movlw	0x43			;put read address into W
 call	START_SEQ		;initilise start segeunce
 call	BYTE_IN			;read first heading byte
 clrw				;clear W
 addwf	DATA_I, w		;W = DATA_I
 movlw	HEAD_HI			;HEAD_HI is MSByte
 call	BYTE_IN			;read second heading byte
 clrw				;clear W
 movlw	HEAD_LO			;HEAD_LO is LSByte
 ;Section of code that outputs the two heading bytes on PORTB
 movlw	0x07			;W = 7
 movwf	COUNT			;COUNT = 7
 HEAD_HI_BITS	bsf		SYN		;sync pulse
 bcf		SYN		;sync pulse
 btfss	HEAD_HI, 7		;test bit of output
 bcf		HED		;clear output bit
 bsf		HED		;set output bit
 call	CLKWAIT			;5 microsecond wait
 rlf		HEAD_HI, f		;shift data in HEAD_HI
 decfsz	COUNT ,f		;decrement and test COUNT
 goto	HEAD_HI_BITS		;output mext bit
 movlw	0x07			;W = 7
 HEAD_LO_BITS	bsf		SYN		;sync pulse
 bcf		SYN		;sync pulse
 btfss	HEAD_LO, 7		;test bit of output
 rlf		HEAD_LO, f		;shift data in HEAD_HI
 goto	HEAD_LO_BITS		;output mext bit
 bsf		HED		;toggle output a few times
 bcf		HED		;so that you know all bits
 bsf		HED		;have been output
 bcf		HED 		;successfully
 bsf		HED
 bcf		HED
 bsf		HED
 bcf		HED
 ;loop infinately around the get heading and output heading code (300us pause)
 movlw	0x32			;d'50'
 movwf	COUNTC
 ABOVE			call	CLKWAIT			;5us wait
 decfsz	COUNTC
 goto	ABOVE
 goto 	HEADING_IN		;get new heading data
 end
		| PCM programmer
				|  Posted: Thu Jan 04, 2007 2:44 pm |   |
				| This forum is not about Microchip Assembly language.    That's what your program is written in.   This forum is about the C language.
 We don't usually like to work on ASM programs.
 Here is a tutorial web page on the using PIC assembly language.
 Read "Tutorial 7" which is about using the serial port:
 http://www.winpicprog.co.uk/pic_tutorial.htm
 If you have further questions about PIC assembly language
 programming, try to ask them on the Microchip forum.
 Here's the main forum page:
 http://forum.microchip.com/
 Try this forum for information on the serial port:
 SCI/USART/EUSART
 | You cannot post new topics in this forum You cannot reply to topics in this forum
