18f4685 encoder problem
Lemosek
PostPosted: Wed Feb 15, 2012 8:32 am     Reply with quote
I found on this forum code from Mr. Ttelmah to read encoder position.
I try using this, but I have some problems.
My code:
//obsługa enkodera
#int_ext
void int_rb_isr(void) {
   static int8 old;
   static int8 new;
   static int8 value;
   new=PORTB; //You don't need a separate function for this....
   //Assuming the encoder is on B1, and B2
   //Now I have to decode the quadrature changes. There are four
   //possibilities:
   //I can have a rising or falling edge, on each of the two inputs. I have to
   //look at the state of the other bit, and increment/decrement according to
   //this.
   value=new^old;
   //'value', now has the bit set, which has changed
   if (value & 0x2) {
      //Here the low bit has changed
      if (new & 0x2) {
         //Here a rising edge on A
         if (new & 0x4) --position;
         else ++position;
      else {
         //Here a falling edge on A
         if (new & 0x4) ++position;
         else --position;
   else {
      //Here the high bit (B) must have changed
      if (new & 0x4) {
         //Here a rising edge on B
         if (new & 0x2) ++position;
         else --position;
      else {
         //Here a falling edge on B
         if (new & 0x2) --position;
         else ++position;
   old=new;
main
clear_interrupt(INT_RB);
clear_interrupt(INT_EXT);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
  printf(lcd_putc, "%u", position);
My problem is when I turn left I have for example 10 9 10 11. Other side is 11 12 11 10.
Why does this happen ??
My compiler version 4.120
Encoder is connected to RB0 and RB1 pins.
Best regards
R.L.
PostPosted: Wed Feb 15, 2012 10:53 am     Reply with quote
That is not the code I posted, but something 'bodged' from it.
My code uses INT_RB only. As posted the code will only respond to changes on one bit and miss two of the four states.
You also have INT_EXT1 enabled without a handler, which will cause indeterminate behaviour.
What chip are you using (affects what pins can be used).
Lemosek
PostPosted: Wed Feb 15, 2012 11:02 am     Reply with quote
My chip is 18f4685. Maybe my code is wrong.
So how this code I must use. I use RB0(INT0) and RB1(INT1) pins.
I use INT_EXT because this chip don't have INT_RB1 and INT_RB0.
Best regards
R.L.
PostPosted: Wed Feb 15, 2012 12:47 pm     Reply with quote
Get familiar to using the 'search' function on this forum. You'll soon find a zillion answers to encoder. It's up to you to decide which best suits your project.
If your PIC has INT_RB, it's a simple matter to get 2 encoders to work with the B7...4 pins.
you could also look at the examples in the examples folder......
Lemosek
PostPosted: Wed Feb 15, 2012 1:13 pm     Reply with quote
Hello, In example folder, example don't use the interrupt. I can't change pcb to connect encoder to RB7..4. I need to use INT0(RB0) and INT1(RB1).
Can someone help me ??
Best regards
R.L.
Lemosek
PostPosted: Thu Feb 16, 2012 4:20 am     Reply with quote
Hello, I solve My problem code below
#int_ext high
   static int8 old;
   static int8 new;
   static int8 value;
   new=PORTB;
   value=new^old;
   if (value & 0x1) {
      if (new & 0x1) {
         if (new & 0x2) position--;
         else position++;
      else {
         if (new & 0x2) position++;
         else position--;
   else {
      if (new & 0x2) {
         if (new & 0x1) position++;
         else position--;
      else {
         if (new & 0x1) position--;
         else position++;
   old=new;
main
I don't known why I must add clear_interrupt at interrupt subroutine ??
Best regards
R.L.
