PIC18F46J11 Reset problem
Chibouraska
PostPosted: Fri Feb 12, 2010 1:12 pm     Reply with quote
Hi!
I'm working on a project using PIC18F46J11 MCU, everything goes good but the micro keeps resetting after 2 minutes and 50 seconds(about). I tried playing around with fuses, taking some out but I still get the same problems.
The MCU is well decoupled with .1u caps. There is no WDT enabled. Any idea would be well appreciated.
thanks !
AC
PostPosted: Fri Feb 12, 2010 1:24 pm     Reply with quote
Post a very small test program that shows the problem. For example,
you could have a program that displays "Hello World" on a terminal,
and then have it stop in a continuous while(1) loop at the end of main().
If the program is resetting, it will display "Hello World" over and over
again, every 2 minutes and 50 seconds.
Try that and post the results.
The program that you post must be small, and it must compile with
no errors.
Also post your compiler version.
PostPosted: Fri Feb 12, 2010 1:56 pm     Reply with quote
Thanks for your help!
OK i made a small project using the same hardware (same PCB)
void main {
  fprintf(UART1,"RESETTING !!!");
  while (TRUE) {
    fprintf(UART1,"LOOPING !");
And the same thing happened after 2 mins 50 secs i see RESETTING !!!
Im a bit confused it looks like a hardware problem but why does it reset
at same interval each time, Thanks
AC
PostPosted: Fri Feb 12, 2010 2:10 pm     Reply with quote
no errors.
You posted a code fragment. Post a complete, compilable program.
To be compilable, it must have an #include, #fuses, #use delay,
#use rs232
, etc., statements.
And also this:
Chibouraska
PostPosted: Fri Feb 12, 2010 3:00 pm     Reply with quote
Compiler version 4.099
#include <18F46J11.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH(>10mhz for PCD)
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES NOWPCFG
#FUSES WPBEG
#FUSES WPDIS
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES T1DIG
#FUSES MSSPMSK7
#FUSES DSWDT2147483648
#FUSES DSWDT
#FUSES DSBOR
#FUSES RTCOSC_T1
#FUSES DSWDTOSC_INT
#FUSES WPFP0
#FUSES WPFP1
#FUSES WPFP2
#FUSES WPFP3
#FUSES WPFP4
#FUSES WPFP5
#FUSES NOCPUDIV
#use rs232(STREAM=UART1,uart1, baud=9600)
Thanks!!
Chibouraska
PostPosted: Fri Feb 12, 2010 3:21 pm     Reply with quote
OK i compiled the same little program on machine that is running ver 4.104
of the compiler and i didnt get no reset of the MCU. I guess it was something
with the compiler at ver 4.099. Anybody have an idea of why ???
PostPosted: Fri Feb 12, 2010 3:42 pm     Reply with quote
I installed vs. 4.099 and compiled your program, and ran it on a 18F24J11
on a PicDem2-Plus board. I don't have a 18F46J11, but the 18F24J11 is
in the same family. It worked. I changed the loop delay to be every
60 seconds (1 second was too short). Here is the display after several
minutes:
RESETTING !!!LOOPING !LOOPING !LOOPING !LOOPING !LOOPING !
This is with vs. 4.099.
Chibouraska
PostPosted: Fri Feb 12, 2010 9:56 pm     Reply with quote
Thanks PCM_Programmer, anyway it works for me using the last version
of the compiler, it is possible that there was an issue with this device(18F46j11) because it's a recent one, i don't know, but i would like to.
I will get a 18F24j11 device to try. thanks again!
AC
