rs232 - mysql
piire
rs232 - mysql
PostPosted: Tue Feb 09, 2010 3:52 pm     Reply with quote
Hi there,
I'm doing a project where I have a sensor which is connected to a pic microcontroller and then to a max232 chip. I have coded the microcontroller to output the data from the sensor to the rs232. I can see the output on hyperterminal. Now I would like to put this data into mysql so that I can write a php web page for this data. What would be the easiest way to get the data into mysql? Are there any other programs I have to write?
Thanks for your help
piire!
bungee-
PostPosted: Tue Feb 09, 2010 5:14 pm     Reply with quote
You have to write a program for your PC to read from com port and feed that data into your database.
You could also feed all that data do a txt file and in later process import it to mysql with PHP ...
A lot of possibilities ... google is your friend Wink
