Interrupt on change.
one_Question
PostPosted: Sun Feb 07, 2010 2:51 pm     Reply with quote
What is the syntax and use of new change on port function.
Regards,
Dan
PostPosted: Sun Feb 07, 2010 6:12 pm     Reply with quote
Here is a test program which shows what the input_change_x() function
does. It's not a finished, useful program. It just displays the "delta"
variable whenever button4 or button5 is pressed or released. Button4
is a pushbutton connected to pin RB4. Button5 is connected to pin RB5.
When a button is pushed, it connects the pin to ground. When it's not
pushed, a pull-up holds the pin at a logic high level.
As a test, I pressed and released button4 four times. Then I pressed
and released button5 three times. It displayed the following output
on the serial terminal. Each pair ("10 10") represents a press and a
release of the button. "10" is the Hex bitmask for pin RB4. "20" is the
hex bitmask for pin RB5.
10 10 10 10 10 10 10 10 20 20 20 20 20 20 20 20
I don't want to write a complete "button state detection" program.
I only wanted to make this simple test program:
#include <16F877.H>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
int8 delta = 0;
#define BUTTON4_MASK 0x10  // Button on pin B4
#define BUTTON5_MASK 0x20  // Button on pin B5
#define ALL_BUTTONS_MASK (BUTTON4_MASK | BUTTON5_MASK)
#int_rb
void rb_isr(void)
delta = input_change_b() & ALL_BUTTONS_MASK;
port_b_pullups(TRUE);
delay_us(10);
input_change_b();    // Init Change_B state
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
   if(delta)
      printf("%X ", delta);
      delta = 0;
PostPosted: Mon Feb 08, 2010 12:05 pm     Reply with quote
