Help With a PWM code for PIC16F690
williamcoral
PostPosted: Mon Feb 08, 2010 6:55 pm     Reply with quote
Hi, I have this PWM code for the PIC16F690 but I don't know what is the problem because I make the simulation with Proteus (ISIS) and the output (pins P1B, P1C, and P1D) stay low always.
My CCS compiler vs. is 4.093
PD. I copied the code from another post of "PCM programmer"
#include <16F690.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOMCLR
#use delay(clock=8000000)
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
setup_timer_2(T2_DIV_BY_16, 124, 1);  // 1000 Hz
set_pwm1_duty(31);  // 25% duty cycle
//!// Enable PWM pins P1B, P1C, and P1D for output.
//!// Note:  P1A is done by the compiler.
output_low(P1B);
output_low(P1C);
output_low(P1D);
// Steer the PWM output to all four P1x pins.
setup_ccp1(CCP_PWM_H_H | CCP_PULSE_STEERING_A
                       | CCP_PULSE_STEERING_B
                       | CCP_PULSE_STEERING_C
                       | CCP_PULSE_STEERING_D );
williamcoral
voila c'est bon
PostPosted: Mon Feb 08, 2010 7:13 pm     Reply with quote
This is the problem with the code, this line of code was placed wrong:
This is the good code and works fine with Proteus:
#include <16F690.h>
#define P1A PIN_C5
#define P1B PIN_C4
#define P1C PIN_C3
#define P1D PIN_C2
output_low(P1B);
output_low(P1C);
output_low(P1D);
PostPosted: Mon Feb 08, 2010 8:21 pm     Reply with quote
It's likely a problem with the Proteus simulator.
