icesynth
Joined: 03 Sep 2007 Posts: 32 Location: Edmonton, Alberta
Cannot write SPI2CON1 Register... |
Posted: Mon Feb 08, 2010 11:03 pm |
I am trying to write the SPI2CON1 register, and it is not accepting the value written to it:
#fuses XT, PR_PLL, NOCOE, NOWRTB, NOPUT, NOWRTSS, NOPROTECT, NORSS, NOWDT, NOWINDIS
#FUSES DEBUG //Debug mode for ICD
#FUSES NOSSS //No secure segment
#FUSES NORSS //No secure segment RAM
i16_previous = SPI2CON1;// Get previous state.i16_new = 0x0020; // Data we are sending...
SPI2CON1 = i16_new; // Write data to the register
i16_result = SPI2CON1; // Read data from the register
SPI2STAT = 0b1000000000000000; // Enable SPI
// Print out the written and read data.
fprintf( SERIAL2, "\n\r -Previous: %LX, New: %LX, Result: %LX", i16_previous, i16_new, i16_result);
Program Output: -Previous: 0061, New: 0020, Result: 0061
List File:
.................... i16_previous = SPI2CON1;// Get previous state.
11C2: PUSH 262
11C4: POP 131A
.................... i16_new = 0x0020; // Data we are sending...
11C6: MOV #20,W4
11C8: MOV W4,131C
.................... SPI2CON1 = i16_new; // Write data to the register
11CA: PUSH 131C
11CC: POP 262
.................... i16_result = SPI2CON1; // Read data from the register
11CE: PUSH 262
11D0: POP 131E
.................... SPI2STAT = 0b1000000000000000; // Enable SPI
11D2: MOV #8000,W4
11D4: MOV W4,260
Does anyone know if there a "write protect" mode for the SPI register that I need to disable to accomplish this?
Compiler: 4.104
Device: DSPIC33FJ64GP310-I/PT _________________ Programming for the the real world.
--Chris Burchett
Sylver Technologies Inc.
Posted: Mon Feb 08, 2010 11:33 pm |
From your code snippet, I can't see what you are actually doing, particularly if SPI2CON1 is defined correctly.
There is surely no write protect for SPI registers. SPIxCON should be configured, before setting SPIEN.
From your code, the previous state of SPIEN can't be seen. |
icesynth
Posted: Tue Feb 09, 2010 12:05 am |
Updated the code and the result to show the value before writing.... _________________ Programming for the the real world.
--Chris Burchett
Sylver Technologies Inc. |
icesynth
Solved |
Posted: Tue Feb 09, 2010 12:18 am |
Thanks for the tip, it turns out that the SPI module must be disabled before the mode is changed. _________________ Programming for the the real world.
--Chris Burchett
