Help PIC16F877A e RS232 and radio CAT
PostPosted: Fri Feb 05, 2010 1:02 pm     Reply with quote
Basically I think that the PIC is connected to the RS232 cat radio
but did not send the command PUTS. Hello on LCD is regularly written.
Maybe it takes RS232 interrupt, or maybe not enter in the while loop?
The simulation is all ok, it works perfectly. Any suggestions?
Jo
#include <16F877A.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES PUT                      //Power Up Timer
#use delay(clock=10000000)
#include <LCD.C>
#include <string.h>
#include <stdlib.h>
char pc[6];
char pcc[6];
char pcc1[5];
char pcc2[]="PC";
int16 WATTS;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
lcd_gotoxy(5,1);
printf(lcd_putc "Hello ");
while(true)
   puts("PC;");
   gets(pc);
   pcc[0]=pc[0];
   pcc[1]=pc[1];
   if(!strcmp(pcc,pcc2));
     pcc1[0]=pc[2];
     pcc1[1]=pc[3];
     pcc1[2]=pc[4];
     pcc1[3]=0;
     WATTS=atol(pcc1);
     lcd_gotoxy(9,2);
     printf(lcd_putc,"%lu",WATTS);
     printf(lcd_putc "\f");
