Access to element of structure with pointer(V4.104)
Manzo Saita
PostPosted: Thu Feb 04, 2010 7:03 pm     Reply with quote
Hello.
The access to the element of the structure with the pointer doesn't go well.
Is this a specification?
typedef struct
   int1   open;
   uint32 holdSect;
   uint8  index;
   uint8  ttribute;
   uint32 orgSect;
   uint32 curSect;
   uint32 size;
   uint32 x;
   uint16 xLocal;
   char   name[8+3];
} st_fileptr;
st_fileptr g_fp;
void foo( void )
   st_fileptr *d;
   d = &g_fp;
   d->size = d->curSect = d->orgSect = 0;
[Result for pic18LF2620 and CCS-C3.249]
g_fp.size, g_fp.curSect and g_fp.orgSect is zero.
[Result for pic18LF2620 and CCS-C4.104]
g_fp.size is 50390016.
g_fp.curSect is 50390016.
--- Manzo Saita ---
PostPosted: Thu Feb 04, 2010 11:59 pm     Reply with quote
Post a test program, in which you initialize those 3 structure elements
to some value, and then run the foo() function, and then display the
results of reading the structure elements. Something like this:
In other words, demonstrate the problem. Post the "before" and "after"
results of running the foo() function.
#include <18F2620.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
typedef struct
   int1   open;
   int32 holdSect;
   int8  index;
   int8  ttribute;
   int32 orgSect;
   int32 curSect;
   int32 size;
   int32 x;
   int16 xLocal;
   char   name[8+3];
}st_fileptr;
//st_fileptr g_fp;
st_fileptr g_fp = {
1,           // open
0x01234567,  // holdSect
0x55,        // index
0xAA,        // ttribute
0x00112233,  // orgSect
0x44556677,  // curSect
0x8899AABB,  // size
0x89ABCDEF,  // x
0x10A9,      // xLocal
{"Filename"}
void foo( void )
st_fileptr *d;
d = &g_fp;
//d = &(st_fileptr *)g_fp;
d->size    = 0x12345678;
d->curSect = 0x89ABCDEF;
d->orgSect = 0x98765432;
printf("size = %lx \r", g_fp.size);
printf("curSect = %lx \r", g_fp.curSect);
printf("orgSect = %lx \r", g_fp.orgSect);
foo();
