FT245rl driver
P51D
FT245rl driver
PostPosted: Fri Feb 05, 2010 3:39 am     Reply with quote
hi all
I've searched for a existing c driver for the ft245 but I didn't find something.
If you have comments to modify the driver so that you can ad this to the code library, only say it.
At the time, I have no possibility to make also a rx-interrupt routine because I have some problem with the sprut burner.
best regards
P51D
driver:
// Definitionen
#define TXE                PIN_D9                        // Transmitt-enabmle pin
#define WR                 PIN_D11                       // Write pin (high peak)
#define RX                 PIN_D8                        // Receive data Pin
#define RD                 PIN_D10                       // Read pin (during read low)
#define PWREN              PIN_F6                        // configurations-status
#define USART_DDR_out      set_tris_d(0x0000 | (1<<9) | (1<<8))
#define USART_DDR_in       set_tris_d(0x00FF | (1<<9) | (1<<8))
#define D0                 PIN_D0                        // Data-Pins
#define D1                 PIN_D1
#define D2                 PIN_D2
#define D3                 PIN_D3
#define D4                 PIN_D4
#define D5                 PIN_D5
#define D6                 PIN_D6
#define D7                 PIN_D7
#define rxBuf_max          100                           // buffer size
static int8 index_rxBuf_R = 0;                           // Index to write RX-Buffer
static int8 index_rxBuf_W = 0;                           // Index to read RX-Buffer
int8 rxBuf[rxBuf_max + 1];                               // RX-Buffer
#define txBuf_max          10                            // buffer size
static int8 index_txBuf_R = 0;                           // Index to write TX-Buffer
static int8 index_txBuf_W = 0;                           // Index to read TX-Buffer
int8 txBuf[txBuf_max + 1];                               // TX-Buffer
// Functions
//=========== INIT ====================================
void ft245_init(void){
   int8 i = 0;
   USART_DDR_in;                                         // Default DDR = input
   output_high(RD);                                      // set control-pins
   output_low(WR);
   for(i=0;i<=txBuf_max;i++){                            // clear buffers
      txBuf[i] = 0;
   i = 0;
   for(i=0;i<=rxBuf_max;i++){
      rxBuf[i] = 0;
   while(input_state(PWREN) == 1);                       // wait until the USB FTDI-configuration
//=========== TX ====================================
// if no new data, return / need to calls in the main
void usart_tx(void){                                     // send-function
   if(input_state(TXE) == 0){                            // if sending possible
      if(index_txBuf_R == index_txBuf_W){                // no new data => return
         return;
      if(index_txBuf_R == txBuf_max){                    // ringbuffer
         index_txBuf_R = 0;
      else{
         index_txBuf_R ++;
      USART_DDR_out;                                     // change ddr from input to output
      output_bit(D0,(txBuf[index_txBuf_R] & 0x01));      // write datas to the ftdi
      output_bit(D1,(txBuf[index_txBuf_R] & 0x02));
      output_bit(D2,(txBuf[index_txBuf_R] & 0x04));
      output_bit(D3,(txBuf[index_txBuf_R] & 0x08));
      output_bit(D4,(txBuf[index_txBuf_R] & 0x10));
      output_bit(D5,(txBuf[index_txBuf_R] & 0x20));
      output_bit(D6,(txBuf[index_txBuf_R] & 0x40));
      output_bit(D7,(txBuf[index_txBuf_R] & 0x80));
      output_high(WR);                                   // new data available
      output_low(WR);
      USART_DDR_in;                                      // set ddr to input
void txBuf_write(int8 parameter){                        // TX buffer handling
   if(index_txBuf_W == txBuf_max){                       // ringbuffer
      index_txBuf_W = 0;
   else{
      index_txBuf_W ++;
   txBuf[index_txBuf_W] = parameter;
//=========== RX ====================================
// need to calls in the main
void usart_rx(void){                                     // read function (polling)
   int8 data = 0;                                        // data
   if(input_state(RX) == 0){                             // if new data in the FTDI buffer
      if(index_rxBuf_W == rxBuf_max){                    // ringbuffer
         index_rxBuf_W = 0;
      else{
         index_rxBuf_W ++;
// take datas and set it dynamic in the buffer
      output_low(RD);                                    // read data
      delay_cycles(1);
      if(input_state(D0) == 1) data |= (1 << 0);
      if(input_state(D1) == 1) data |= (1 << 1);
      if(input_state(D2) == 1) data |= (1 << 2);
      if(input_state(D3) == 1) data |= (1 << 3);
      if(input_state(D4) == 1) data |= (1 << 4);
      if(input_state(D5) == 1) data |= (1 << 5);
      if(input_state(D6) == 1) data |= (1 << 6);
      if(input_state(D7) == 1) data |= (1 << 7);
      rxBuf[index_rxBuf_W] = data;                       // store data
      output_high(RD);                                   // read finished
