two addresses for same function??
loupan
PostPosted: Mon Jan 25, 2010 5:42 pm     Reply with quote
In tracking down unexpected program behavior, it appears that the compiler is generating two different addresses for the same function.
I am not that familiar with assembly language. Perhaps someone who is can take a look at the excerpts from the symbol table and LST file and confirm or dispell my suspicion.
The function in question is load_sim
From the symbol table, the adrs is show as 007FFA
007FFA  load_sim
Below are the excerpts from the LST file that show the assembly language being generated for each of the 4 calls:
....................          load_sim(G_MAST_NUM);
087B4:  MOVFF  688,B59
087B8:  MOVLB  0
087BA:  RCALL  7FFA
087BC:  MOVLB  6
1BDEC:  MOVFF  688,B59
1BDF0:  MOVLB  0
1BDF2:  CALL   1B956
....................          load_sim(i+1);
15604:  MOVLW  01
15606:  ADDWF  x04,W
15608:  MOVWF  x84
1560A:  MOVFF  FE8,B59
1560E:  MOVLB  0
15610:  CALL   1B956
158D2:  MOVFF  688,B59
158D6:  MOVLB  0
158D8:  CALL   1B956
It looks to me like the correct adrs (7FFA) is called once and another adrs (1B956) is called 3 times. I note that RCALL is being used once and CALL is being used 3 times, but aren't they suppose to resolve to the same adrs?
I got to this point by single stepping at the point where load_sim is called, and the next instruction indeed executes at adrs 1B956, right in the middle of a totally different routine. Obviously the program behavior is nonsensical beyond that point.
The listing for the actual definition of the function shows that it indeed starts at 7FAA as shown below:
.................... void load_sim(int sim_val) {
....................    int i,  num_pwr_pts;
....................    int16 max_pwr, adc_at_pwr_n;
....................    float start, delta;
....................    int band_to_load;
....................    val_to_load = G_VALS[band_num -1];
07FFA:  MOVLW  01
07FFC:  MOVLB  B
07FFE:  SUBWF  x59,W
08000:  CLRF   03
08002:  ADDLW  89
08004:  MOVWF  FE9
08006:  MOVLW  06
08008:  ADDWFC 03,W
0800A:  MOVWF  FEA
0800C:  MOVFF  FEF,B68
This is happening on 4.100 but it also happens on 4.104 and I backtracked to 4.100 to see if I still had the problem.
The processor is a PIC18F8722 with 128K of adrs space, about 90% used.
Shifting/adding code around sometimes moves this behavior to a different routine.
Thanks for any suggestions.
Regards,
loupan
PostPosted: Mon Jan 25, 2010 6:09 pm     Reply with quote
Download vs. 4.099 and try it. (Assuming you have download rights).
http://www.ccsinfo.com/compilerupdates.php
loupan
PostPosted: Mon Jan 25, 2010 7:11 pm     Reply with quote
Thanks PCM programmer. I know there were some major changes introduced in 4.100.
Tried it on 4.099 - same problem.
Based on the LST info that I posted, does my analysis seem to be correct? Two different addresses for the same function?
loupan
PostPosted: Tue Jan 26, 2010 2:57 am     Reply with quote
Are you doing anything unusual in your code ? Are you using #build,
#separate, #org, #opt, etc., in your program ? Are you using "multiple
compilation units" ?
loupan
PostPosted: Tue Jan 26, 2010 3:44 am     Reply with quote
No - not using anything special that relocates code, blocks out address ranges, etc. I did not see this behavior when the code occupied a smaller percentage of the total rom space.
PostPosted: Tue Jan 26, 2010 1:41 pm     Reply with quote
07FFA: MOVLW 01
07FFC: MOVLB B
07FFE: SUBWF x59,W
08000: CLRF 03
08002: ADDLW 89
08004: MOVWF FE9
08006: MOVLW 06
08008: ADDWFC 03,W
0800A: MOVWF FEA
I noticed that the load_sim() function is crossing a 32K boundary.
What if the compiler has problems with functions that do this ?
Try an experiment. Use an #org statement to prevent the
compiler from using the last 2 bytes in the first 32K block.
Then look in the .LST file to see where it places the load_sim()
function. Also look at the ASM code that calls it. See if this
fixes the problem. Example:
#include <18F8722.h>
#fuses XT,NOWDT,PUT,BROWNOUT,NOLVP
// Reserve the last 2 bytes in the first 32K block.
// This should prevent the CCS compiler from placing
// code that crosses the 0x7FFF-0x8000 boundary.
#org 0x7FFE, 0x7FFF {}
Also, it just occurred to me that this PIC has 128 KB of ROM space.
You might want to put similar #org statements at all 32K boundaries
in the PIC. So in addition to the #org statement above, add these:
#org 0xFFFE, 0xFFFF {}    // Last 2 bytes in 2nd 32K block
#org 0x17FFE, 0x17FFF {}  // Last 2 bytes in 3rd 32K block
loupan
PostPosted: Tue Jan 26, 2010 6:02 pm     Reply with quote
Thanks.
With the three org statements, the function in question now resolves to the same adrs in all 4 calls. As I mentioned earlier, shifting things around sometimes eliminates the problem or moves it to another function. So I can't be sure if the problem did not occur as a result of preventing routines from crossing 32k boundaries, or simply from the shifting that took place as a result of the org statements. I will try this work-around and if I do not see this problem over the next few days as the code is modified, I would say your hunch is correct.
In any case, it would behoove CCS to add a sanity check to make sure all args of CALLs and RCALLs map to a valid adrs in the symbol table.
Thanks again PCM programmer. I'll respond again if the problem resurfaces with the org statements, or if I do not see the problem in a few days as the code continues to churn.
Regards,
loupan
loupan
PostPosted: Fri Jan 29, 2010 8:51 am     Reply with quote
PCM programmer.
even with the three org statements you recommended to prevent functions spanning 32K boundaries, the problem still happens.
The excerpts below show another example that I captured with two of the 4 calls to a function resolving to the correct address, and the other 2 calls mapping to an address in the middle of another function. The latter two calls do indeed cause execution to jump to the incorrect address as I confirmed with breakpoints and single stepping.
Interestingly, if I swap the declaration of the affected function with an adjacent declaration in the application header file and recompile, the compiler generates the same (correct) address for all 4 calls, but of course, the problem may very well have moved to another function.
I will refer this to CCS and let you know how things turn out.
Thanks again.
loupan
// Excerpts from lst file, function definition and 4 calls
.................... void update_use_trim_flag () {
....................    if (G_FWD_RATIO == 1.0)
06F38:  MOVFF  6D4,BCF
06F3C:  MOVFF  6D3,BCE
06F40:  MOVFF  6D2,BCD
....................    update_use_trim_flag();
07EB8:  MOVLB  0
07EBA:  CALL   6F38
06F92:  RCALL  6F38
....................          update_use_trim_flag ();
1C566:  CALL   1AD2E
1CF72:  CALL   1AD2E
