Bitbanging SPI
rwskinner
Bitbanging SPI
PostPosted: Thu Jan 28, 2010 7:55 pm     Reply with quote
Okay, please remember I'm a amateur and trying to learn....
I'm having to manually bit bang a ADS7953, 16 channel, 12 bit ADC.
http://focus.ti.com/lit/ds/symlink/ads7953.pdf
A long time ago, I've done some of the simple stuff where I lower CS, toggle the CLk to start a conversion then I just shift in 8 bits for my reading. This critter is a little more complicated.
Please see if I have this logic right....
1) While I'm shifting out 16 bit on SDI there is data coming back from the previous conversion at the same time on SDO.
Pseudo code...
Shift out first 16 bits for the Config
Ignore DOut
Shift out 2nd 16 bits for the Operation Registers
Ignore DOUT
For this example, the above put the ADC in Auto1 mode, self incrementing on the channels.
Lower CS
Lower DIN (in auto mode so it can be all zeros)
for (i=0; i < 16; i++)
make clock high
short delay
read in bit on DO
Lower clock
Now I have data from the conversion with the first 4 bits being the channel # and the remaining 12 bits the ADC Value.
Is this close to being correct?
FvM
PostPosted: Fri Jan 29, 2010 12:34 am     Reply with quote
It's basically correct. I have two comments, however.
- You can use CCS software SPI built-in functions to achieve the same
- Operating a 1 MSPS high speed ADC with software SPI seems to me like "cast pearls before swine".
rwskinner
PostPosted: Fri Jan 29, 2010 5:56 am     Reply with quote
Thanks, I give it a try today.
18F4550 MSSP shares pins with USART so both can not use hardware at the same time. Already using hardware RS232. MC Buggered this one up a little. I guess they figured if you would be using USB, you would not be using RS232.
rwskinner
PostPosted: Fri Jan 29, 2010 8:27 am     Reply with quote
Here is what I have.
Again, I'm trying to learn the timing maps....
I'm getting changing data back, but I'm only getting 6 bits back, the 10 msb are zero.
I'm using the 16 channel, 12 bit version (ADS7953).
Don't be too hard on me Smile
#define ADS7953_CLK  PIN_B1   //Clock
#define ADS7953_DOUT PIN_D4   //Data from Chip
#define ADS7953_CS   PIN_D5   //Chip Select
#define ADS7953_DIN  PIN_A2   //must change  Data to Chip
//Base routines
void write_ADS7953(int16 data) //Sends 16 bits of data
   int i;
   output_low(ADS7953_CLK);    //Initial State
   output_low(ADS7953_CS);
   delay_us(1);
   output_high(ADS7953_CS);    //CS High for two clock cycles
   for(i=0;i<=2;i++)           //Toggle Clk twice,lo to hi
      output_high(ADS7953_CLK);
      delay_us(1);
      delay_us(1);
   output_low(ADS7953_CS);    //clk low, now CS low
   //start shifting data in
   for(i=1;i<=16;++i)
      output_bit(ADS7953_DIN, shift_left(&data,2,0));
   output_high(ADS7953_CS);   //End serial
//Base routines
long read_ADS7953()  //Gets 16 bits of data
   int i;
   long data;
   data=0;
   output_low(ADS7953_CLK);   //Inital States
   delay_us(1);
   output_high(ADS7953_CS);  //CS high for 2 clk cycles
   for(i=0;i<=2;i++)             //toggle clk twice, lo to hi
      delay_us(1);
      delay_us(1);
   output_low(ADS7953_CS);       //make CS low
   for(i=0;i<16;++i) {           // shift data from ADS
      delay_us(1);
      shift_left(&data,2,input(ADS7953_DOUT));
      delay_us(1);
   return(data);
//0 = Manual
//1 = Auto1
//2 = Auto2
void init_ADS7953(byte mode)
{ long ModeCfg, ProgCfg, ChanCfg;
  //Only support Auto1 for Testing
  PGM1 Mode Control Register Layout (Frame 1)
  Bit 0-3     GPIO Data for Outputs (Right)
  Bit 4       0= Output 4 bit channel data with ADC Val,
              1= Output 4 bit GPIO Values
  Bit 5       0= Normal 1=Power Down after conversion
  Bit 6       0= 2.5 volt Full Scale  1 = 5.0 volt full scale
  Bit 7-9     Do not care
  Bit 10      0 = Inc Channel  1= Start at lowest channel
  Bit 11      0 = Retains Bits 0-10 every frame  1= Program 0-10
  Bit 12-15   0010 = Auto Mode, 0001 = reset state
 ModeCfg = 0b001000000100000;
  PGM2 Program Register layout (Frame 2)
  Bits 0-11   Don't Care
  Bits 12-15  1000 - Enter Auto1 Mode
 ProgCfg = 0b100000000000000;
  PGM3 Channel Selection  (Frame 3)
  Bits 0-15   Which CHannels are on for us, 1111 1111 1111 1111
 ChanCfg = 0b1111111111111111;
 //Write Mode Control Configuration Frame 1
 Write_ADS7953(ModeCfg);
 //Write Program Registers  Frame 2
 Write_ADS7953(ProgCfg);
 //Write Channel Selections
 Write_ADS7953(ChanCfg);
rwskinner
PostPosted: Fri Jan 29, 2010 11:27 am     Reply with quote
I got it......
