Inter-SEGMENT Transition Issue, or STACK overflow? |
Posted: Mon Jan 25, 2010 4:44 am |
I am working in a project with a 16F876A.
The project is taking a 46% of the ROM (3.68KB out of 8KB).
The thing is that when a new function is added, the program stops working as it should.
This miss-behavior cannot be blamed on the new funcionallity. To be more concise: This new function is outside the “infinite loop” of the program, is a display presentation that is only executed once, and works nice.
After that, the infinite loop is entered and it is there where the behavior goes erratic and garbled.
I thought it had to be with some inter-SEGMENT transition, or some piece of code too large to be located in one segment.
I went through the output files of the compiler to look for something suspicious, but I didn’t.
MAIN = 22% ROM
1 unused SEGMENT
The rest of funcions range from 1% to 14% (mostly 1 to 6%)
In case is of some help to any kind of genius, this is a comparison between the two compilations, first with the added function and second without it:
WITH ADDED FUNCTION WITHOUT NEW FUNCTION
Segment Used Free Segment Used Free
00000-00003 4 0 00000-00003 4 0
00004-00039 54 0 00004-00039 54 0
0003A-007FF 1985 5 0003A-007FF 1936 54
00800-00FFF 1420 628 00800-00FFF 1637 411
01000-017FF 926 1122 01000-017FF 0 2048
01800-01EFF 0 1792 01800-01EFF 0 1792 |
I also tried to add a #SEPARATE directive above each function in order to prevent the linker from doing INLINEs, but the result keeps being the same.
I also thought about some stack overflow issue, but the CALL TREE states that only 7 levels are used:
7 worst case (6 in main + 1 for interrupts)
I keep thinking that some of these are the root of the problem, but I can’t think a way to find it out.
Please, some advice on this?
COMPILER VERSION: CCS PCM C Compiler, Version 4.068, 11166 |
Posted: Mon Jan 25, 2010 4:58 am |
I'd be looking at the possibility of a _RAM_ problem. What you describe,is 'semi-classic', for something using a pointer/array, and overwriting a variable, that it shouldn't touch, which then results in the part of the program that does use that variable, receiving unexpected values....
Classic things would be 'forgetting' that a string needs space for the terminating character, and only assiging 10 locations for a 10 character string, resulting in the next variable getting overwritten.
Posted: Mon Jan 25, 2010 6:04 am |
Yes, you are right, that could be happening.
Nevertheless the new function is not adding more than 14 variables.
Code: | RAM used: 140 (39%) at main() level
198 (55%) worst case |
Of course it could also be a dormant error that has arises when this function has been added. Nothing to do with amount of RAM available.
Anyway, I would like to have any argument to discard the possibility of the SEGMENT issue or the STACK. I don’t know if the information provided by the .STA file is reliable enough to forget about the matter, or on the contrary, some other precautions and checks have to be done. |
