		| Author | Message |
		| GLADKIH_UA Guest
				| PIC24F64GA002 |
				|  Posted: Thu Jan 21, 2010 2:06 pm |   |
				| Hello people. Sorry by my language - I'm from Ukraine. I have a question. I want to have 32Mhz in this PIC.
  	  | Code: |  	  | #FUSES NOWDT                    //No Watch Dog Timer
 //#FUSES NOCOE                    //Device will reset into operational mode
 #FUSES ICSP1                    //ICD uses PGC2/PGD2 pins
 #FUSES WINDIS                   //Watch Dog Timer in non-Window mode
 #FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
 #FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
 #FUSES FRC_PLL                  //Internal Fast RC oscillator with PLL
 #FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
 #FUSES OSCIO                    //OSC2 is general purpose output
 #FUSES NOPR                     //Pimary oscillater disabled
 #FUSES I2C1SELd
 #use delay(clock=32000000)
 Before programming I see that frequency is not 32Mhz. She is 16Mhz or something like that.
 Please help me. And I have question about #Fuses. Where can I read about every #Fuses of this series PIC24F.
		| FvM
				|  Posted: Thu Jan 21, 2010 3:24 pm |   |
				| You find all fuses details in the Microchip datasheet of the respective chip, in the Special Features/Configuration Bits paragraph. In addition you should always read the oscillator configuration chapter to understand
 the clocking options and configuration parameters of the chip.
 I didn't use PIC24 with FRC_PLL yet, but as far as I understand, the fuses are basically correct. The CLKDIV
 register RCDIV bits are however defaulting to a divider factor of 2, so you get 16 MHz after PLL. CCS C
 has a setup_oscillator() built-in function to set among others CLKDIV register.
 Unfortunately, I can't tell you the correct parameters for your setting. If it can't be derived from the given documentation,
 I would most likely program the register directly.
		| gladkih Guest
				|  Posted: Fri Jan 22, 2010 8:57 am |   |
				|  	  | FvM wrote: |  	  | You find all fuses details in the Microchip datasheet of the respective chip, in the Special Features/Configuration Bits paragraph. In addition you should always read the oscillator configuration chapter to understand
 thanks for answer.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
