How to stop interrupt the TIMER0
s0011513
PostPosted: Sat Jan 23, 2010 4:55 am     Reply with quote
When EXTERNAL INTERRUPT is clear(High to low). I want to stop INTERRUPT TIMER0.
How to stop interrupt the TIMER0?
Can I use "disable_interrupts(INT_TIMER0);" in order to stop interrupt timer0?
#include <16F688.h>
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=9600, xmit=PIN_C4, rcv=PIN_C5)
unsigned int i=0;
#INT_TIMER0
void Timer0_ISR()
   i++;
#INT_EXT
void EXT_ISR()
   printf("%d",i);
void main ()
   enable_interrupts(INT_EXT);
   ext_int_edge(H_TO_L);
   while (TRUE)
    if(!input(PIN_A0))
     set_timer0(0);
