need help on MCP4921 DAC
arawana
PostPosted: Mon Jan 18, 2010 10:40 pm     Reply with quote
I want to use MCP4921 a 10bit DAC. I want to connect it to PIC16F877A.
But I have confuse on PIN CS on MCP4921.. Is it have to connect to pin RC0 or RC1 or RC2 or RE1?
Someone who had use MCP4921 please help me?
PostPosted: Mon Jan 18, 2010 11:08 pm     Reply with quote
CCS has a driver. Are you using it ?
c:\program files\picc\drivers\mcp4921.c
The mcp4921.c driver file lists some default pins for the DAC signals.
You can change these pins to other pins if you want to.
#define DAC_CS     PIN_B0
#define DAC_CLK    PIN_B1
#define DAC_DI     PIN_B2
#define DAC_LDAC   PIN_B4
