PIC12F675 - INTRC_IO with NOMCLR not allowed?
Squintz
PostPosted: Thu Jan 14, 2010 11:03 am     Reply with quote
I'm new! When trying to program I get this message:
"PICkit 3 does not support programming this device if both the internal oscillator and internal MCLR are selected. You may continue programming, but you are encouraged to cancel, reconfigure your device and try again. Select OK to continue programming or CANCEL to avoid programming."
So my question is... Can I use GP3 without setting #fuses NOMCLR? I want to use #fuses #INTRC_IO but also want to use pin 4 (GP3) as an input. What am I doing wrong?
#include <12F675.h>
#fuses INTRC_IO     //Inernal RC Oscillator
#fuses NOWDT        //No Watchdog Timer
#fuses NOBROWNOUT   //No Brownout Detection
#fuses NOMCLR       //No Master Clear Reset. Used for I/O Instead
#use delay(clock=31000) //
      // if the Switch and the LED are opposite then toggle the power
      if(input(PIN_A3)^input(PIN_A2))       // XOR Switch to LED
         //Turn the unit on
          output_low(PIN_A5);                 // Simulate power button press
            delay_ms(500);                  // Wait with button pressed...
            output_float(PIN_A5);            // Simulate power button release
      delay_ms(200);                         // Wait before checking again.
PostPosted: Thu Jan 14, 2010 5:31 pm     Reply with quote
This is a Microchip issue. The Microchip forum is the best place to look.
Someone offers an explanation near the end of this thread.
It's about using the PicKit 2. Apparently the PicKit 2 has
a standalone application program (in addition to MPLAB)
that can be configured to fix the problem:
http://www.microchip.com/forums/tm.aspx?m=461172
This thread is on the PicKit 3, and the same problem:
http://www.microchip.com/forums/tm.aspx?m=461553
What is your Vdd voltage on the PIC ?
Linxroot
PostPosted: Wed Jun 17, 2015 12:50 pm     Reply with quote
The VDD is 5,07 V RMS
