why does this code go to sleep
brianm
PostPosted: Mon Jan 11, 2010 12:50 pm     Reply with quote
this code does not loop....so simple yet pulling my hair out...yikes
thanks
#include <16F690.h>
#device adc=10
#fuses INTRC_IO, NOWDT, BROWNOUT
int main() {
set_tris_a(0b00000000);    // 1 is input  0 is output
set_tris_b(0b10000000);
set_tris_c(0b00010000);
while(1==1)
output_high(pin_c0);
PostPosted: Mon Jan 11, 2010 12:51 pm     Reply with quote
How do you know it goes to "sleep" ? What tests are you doing to
prove this ?
brianm
led isnt staying lite
PostPosted: Mon Jan 11, 2010 1:06 pm     Reply with quote
the led on pin c0.....is not staying on...it comes on once then off....and thats it.
shouldnt the while loop keep executing.
PostPosted: Mon Jan 11, 2010 1:10 pm     Reply with quote
How is this being tested ? In hardware or in a simulator ?
Does the LED have a series resistor, to limit the current ?
brianm
testing
PostPosted: Mon Jan 11, 2010 4:08 pm     Reply with quote
Testing is being done with hardware...breadboard.
The hardware works as I wrote an assembler program to do the same thing and no problem.
Led connected in series with pin C0 via a 220 ohm resistor.
Ultimately I want to have 2 switch used to increment/decrement a number used as an alarm point.
I do see the led come on once when I first burn the PIC but then I expected the led to stay on for ever.
Brian
PostPosted: Mon Jan 11, 2010 4:41 pm     Reply with quote
Post your compiler version. It's given at the top of the .LST file, which
will be in your project directory after a successful compilation. It's a
4-digit number in this format: x.xxx
rnielsen
PostPosted: Mon Jan 11, 2010 5:15 pm     Reply with quote
Try flashing the LED. That will tell you if it is, actually, sleeping.
  output_low(pin_c0);
Or something like that. The LED should flash and not stop.
Ronald
brianm
further information
PostPosted: Tue Jan 12, 2010 9:51 am     Reply with quote
Version numbers
CCS PCM C Compiler, Version 4.062, 41368 12-Jan-10 09:40
mplab 8.43
windows vista
programmer pickit2
in mplabsim it seems to work the way it is suppose to...although I am not that versed on the simulator, this has been a good chance to make use of it as it is a simple program to follow....
include the .lst file for reference
Thanks for the flashing idea...but I tried that too....in case I had the wrong logic but still no joy....
               Filename: F:\microchip\projects in c\first c program.lst
               ROM used: 83 words (2%)
                         Largest free fragment is 2048
               RAM used: 7 (3%) at main() level
                         8 (3%) worst case
               Stack:    1 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   019
0003:  NOP
.................... #include <16F690.h>
.................... //////// Standard Header file for the PIC16F690 device ////////////////
.................... #device PIC16F690
.................... #list
.................... #fuses INTRC_IO, NOWDT, BROWNOUT
.................... #use delay(clock=4000000)
0004:  MOVLW  27
0005:  MOVWF  04
0006:  BCF    03.7
0007:  MOVF   00,W
0008:  BTFSC  03.2
0009:  GOTO   018
000A:  MOVLW  01
000B:  MOVWF  21
000C:  CLRF   20
000D:  DECFSZ 20,F
000E:  GOTO   00D
000F:  DECFSZ 21,F
0010:  GOTO   00C
0011:  MOVLW  4A
0012:  MOVWF  20
0013:  DECFSZ 20,F
0014:  GOTO   013
0015:  GOTO   016
0016:  DECFSZ 00,F
0017:  GOTO   00A
0018:  RETLW  00
.................... int main() {
0019:  CLRF   04
001A:  BCF    03.7
001B:  MOVLW  1F
001C:  ANDWF  03,F
001D:  MOVLW  61
001E:  BSF    03.5
001F:  MOVWF  0F
0020:  MOVF   0F,W
0021:  BCF    03.5
0022:  BSF    03.6
0023:  BCF    1F.0
0024:  BCF    1F.1
0025:  BCF    1F.2
0026:  BCF    1F.3
0027:  BCF    03.6
0028:  BCF    1F.6
0029:  MOVLW  00
002A:  BSF    03.6
002B:  MOVWF  1E
002C:  CLRF   19
002D:  CLRF   1A
002E:  BSF    03.5
002F:  CLRF   1E
0030:  BCF    03.5
0031:  CLRF   1B
0032:  BCF    03.6
0033:  BCF    0D.5
.................... set_tris_a(0b00000000);    // 1 is input  0 is output
0034:  MOVLW  00
0035:  BSF    03.5
0036:  MOVWF  05
.................... set_tris_b(0b10000000);
0037:  MOVLW  80
0038:  MOVWF  06
.................... set_tris_c(0b00010000);
0039:  MOVLW  10
003A:  MOVWF  07
.................... while(1==1)
.................... output_high(pin_c0);
003B:  BCF    07.0
003C:  BCF    03.5
003D:  BSF    07.0
.................... delay_ms(1000);
003E:  MOVLW  04
003F:  MOVWF  26
0040:  MOVLW  FA
0041:  MOVWF  27
0042:  CALL   004
0043:  DECFSZ 26,F
0044:  GOTO   040
.................... output_low(pin_c0);
0045:  BSF    03.5
0046:  BCF    07.0
0047:  BCF    03.5
0048:  BCF    07.0
0049:  MOVLW  04
004A:  MOVWF  26
004B:  MOVLW  FA
004C:  MOVWF  27
004D:  CALL   004
004E:  DECFSZ 26,F
004F:  GOTO   04B
0050:  BSF    03.5
0051:  GOTO   03B
0052:  SLEEP
Configuration Fuses:
   Word  1: 3FE4   INTRC_IO NOPROTECT BROWNOUT MCLR NOCPD NOWDT PUT IESO FCMEN
drh
PostPosted: Tue Jan 12, 2010 10:03 am     Reply with quote
RC0 is an analog input at power up. You need to configure it for digital I/O.
It's in the data sheet.
David
Henry8
PostPosted: Tue Jan 12, 2010 10:08 am     Reply with quote
Analog / Comparator setup?.
mkuang
PostPosted: Tue Jan 12, 2010 10:11 am     Reply with quote
WIth your original code what do you get at RC0 when you measure it with a voltmeter?
PostPosted: Tue Jan 12, 2010 11:24 am     Reply with quote
I installed vs. 4.062 and used the program in your first post,
and programmed it into a 16F690 on a 3M breadboard. It worked.
However, initially it didn't work. So I reached over and wiggled
the series resistor and pushed it further into the 3M breadboard,
and then it worked. Solidly.
If it doesn't work for you, check all connections. Also:
1. What is the Vdd voltage on the PIC ?
2. Do you have an MCLR pull-up resistor ?
brianm
more inforamtion
PostPosted: Wed Jan 13, 2010 5:00 pm     Reply with quote
ok yes I had a 10k resistor to pin a3 -mclr.....
so i removed it and same thing......so i put a
#fuse nomclr in the program and it worked(s) fine
I still dont understand why it wont work with the mclr held high?
PostPosted: Wed Jan 13, 2010 5:46 pm     Reply with quote
programmer pickit2
In the PICkit 2 User's Guide, on page 11 (pg. 15 in the Acrobat reader),
http://ww1.microchip.com/downloads/en/DeviceDoc/51553E.pdf
it describes a tickbox option in the Programmer menu for the PicKit 2:
Hold Device in Reset -
When checked, the MCLR (VPP) pin is held low (asserted). When
unchecked, the pin is released (tri-stated), allowing an external
pull-up to bring the device out of Reset.
I think it's likely that you have this option selected. It's holding MCLR
in a reset state. If you disable MCLR on the PIC, then it doesn't matter
if that pin is held low.
