Need help to understand this...
kalman
PostPosted: Sat Jan 09, 2010 10:35 pm     Reply with quote
void init_Gyro1DKalman(struct Gyro1DKalman *filterdata, float Q_angle, float Q_gyro, float R_angle)
   filterdata->Q_angle = Q_angle;
   filterdata->Q_gyro  = Q_gyro;
   filterdata->R_angle = R_angle;
Hye I got this code from blog, its for kalman filter, it were much longer but I cut it.
My question is what is the function of:
and
the ....->.... have any meaning?
dyeatman
PostPosted: Sat Jan 09, 2010 10:54 pm     Reply with quote
Structs and pointers to structs are explained here:
http://www.iu.hio.no/~mark/CTutorial/CTutorial.html#Pointers%20to%20Structures
Google and Forum Search are some of your best tools!!!!
PostPosted: Sat Jan 09, 2010 10:55 pm     Reply with quote
This is not a C learning forum. You're expected to learn the C language
outside of this forum. A good way to do this is to read online tutorials.
Here are a few web pages on Pointers and Structures:
http://www.cs.cf.ac.uk/Dave/C/node10.html#SECTION001070000000000000000
http://www.taranets.com/cgi/ts/1.37/ts.ws.pl?w=329;b=282
http://home.netcom.com/~tjensen/ptr/ch5x.htm
http://publications.gbdirect.co.uk/c_book/chapter6/structures.html
kalman
PostPosted: Sun Jan 10, 2010 3:17 am     Reply with quote
sorry, thanks....
kalman
PostPosted: Sun Jan 10, 2010 3:26 am     Reply with quote
Guys, is there any other tutorial page?
A complete tutorial on c...
One more thing, when I compile a code consist of math.h file the compiler give error:
cannot change device type this far into the code
and it open the pic.h file. I need to do inverse sine of some math equation.
dyeatman
PostPosted: Sun Jan 10, 2010 9:44 am     Reply with quote
That error actually is particular to the CCS compiler.
The #include line with your PIC .h file MUST be the first one in the code.
#include <18F458.H>
#fuses XT, NOPROTECT, NOBROWNOUT, NOWDT, NOLVP
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, errors)
If you include a custom .h file the #include line for the PIC must be the first
line of that file.
Here are examples of the two formats:
http://www.ccsinfo.com/forum/viewtopic.php?t=21575
http://www.ccsinfo.com/forum/viewtopic.php?t=26835
If you can't figure it out, post the first 20 or so lines of your code (be sure
to use the CODE button) so we can see what you have.
PostPosted: Sun Jan 10, 2010 3:25 pm     Reply with quote
Here is a tutorial for CCS. It's not perfect. His sample programs are
a little too short. He leaves off the #fuses statement. He doesn't put a
while(1); statement at the end of main(), to prevent the PIC from going
to sleep if the program falls off the end of main(). But it's mostly OK.
http://www.swarthmore.edu/NatSci/echeeve1/Ref/C%20for%20PIC/C_Intro.html
This tutorial is for the Hi-Tech compiler. CCS uses different default
sizes for the datatypes than Hi-Tech does, so it's not completely
applicable. But it's still OK. (In the CCS PCB, PCM, and PCH compilers,
an 'int' is an unsigned 8-bit integer).
http://phy.ntnu.edu.tw/~cchen/ctutor.pdf
You can find more tutorials. Google for: CCS compiler tutorial
dbotkin
PostPosted: Sun Jan 10, 2010 10:49 pm     Reply with quote
And then there is always The C Programming Language, by Kernighan & Ritchie. A little dry perhaps, and not really a tutorial. Still, as a reference it's invaluable. I did most of my C learning from it.
kalman
PostPosted: Tue Jan 12, 2010 4:41 am     Reply with quote
Can I pass input value from adc to struct?
To store the value and then call it back.
Anywhere I can learn this?
