My 24FJ256GB106 can't work at internal Oscillator
sindyme
PostPosted: Tue Jan 12, 2010 3:18 am     Reply with quote
Hello every ~ My 24FJ256GB106 can't work at internal Oscillator
I want to use UART、SPI and USB function.
USB function using the internal USB PLL.
So I select "Fast RC Oscillator with PLL module and the Oscillator input divided by 2 (8Mhz) <--- internal Oscillator at 8Mhz.
Please everyone check my FUSE .h file ~ Thanks !
#FUSES ICS0                    //ICD communication channel 3
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES FRC_PLL                  //Internal Fast RC oscillator with PLL
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is general purpose output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP0
#FUSES PLL2                     //Divide By 2(8MHz oscillator input)
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=8000000)
PostPosted: Tue Jan 12, 2010 3:45 am     Reply with quote
The dataheet clarifies:
While the FRCPLL Oscillator mode is available in
these devices, it should never be used for USB
applications. FRCPLL mode is still available when
the application is not using the USB module.
