HID Descriptor Help...
rwskinner
PostPosted: Fri Jan 15, 2010 1:08 pm     Reply with quote
Can someone help me on figuring out where I messed this up.
Trying to add endpoints to the HID Descriptor. I modified the following sections:
const char USB_CLASS_SPECIFIC_DESC[] = {
      0x06, 0x00, 0xFF, // Usage Page = Vendor Defined
      0x09, 1,            // Usage = IO device
      0xa1, 1,         // Collection = Application
      0x75, 8,         // Report size = 8 (bits)
      0x85, 1          //Report_ID 1
      0x95, 35,        // Report count = Sending to PC
      0x09, 1,         // Usage = Vendor
      0x19, 1,         // Usage minimum
      0x29, 32,        // Usage maximum
      0x15, 0,         // Logical minimum (-128)
      0x25, 255,       // Logical maximum (127)
      0x81, 2,         // Input (Data, Var, Abs)
      0x09, 1,         // Usage = Vendor    //Rport ID 1 Still - From PC to Pic
      0x95, 2,         // Report count = From PC
      0x29, 8,         // Usage maximum
      0x91, 2,         // Output (Data, Var, Abs)
      0x85, 2          // Report_ID 2
      0x95, 2,         // Report count = Sending to PC
      0x29, 2,         // Usage maximum
      0x09, 1,         // Usage = Vendor    //Rport ID 2 Still - From PC to Pic
      0xc0             // End Collection
   #DEFINE USB_TOTAL_CONFIG_LEN  55 //Was  41  //config+interface+class+endpoint+endpoint (2 endpoints)
   const char USB_CONFIG_DESC[] = {
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size          ==1
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)     ==2
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config      ==3,4
         1, //number of interfaces this device supports       ==5
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==6
         0x00, //index of string descriptor for this configuration      ==7
         0xC0, //bit 6=1 if self powered, bit 5=1 if supports remote wakeup (we don't), bits 0-4 unused and bit7=1         ==8
         0x32, //maximum bus power required (maximum milliamperes/2)  (0x32 = 100mA)
   //interface descriptor 1
         USB_DESC_INTERFACE_LEN, //length of descriptor      =10
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =11
         0x00, //number defining this interface (IF we had more than one interface)    ==12
         0x00, //alternate setting     ==13
         3, //number of endpoints       ==14
         0x03, //class code, 03 = HID     ==15
         0x00, //subclass code //boot     ==16
         0x00, //protocol code      ==17
         0x00, //index of string descriptor for interface      ==18
   //class descriptor 1  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor    ==19
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==20
         0x00,0x01, //hid class release number (1.0) (try 1.10)      ==21,22
         0x00, //localized country code (0 = none)       ==23
         0x01, //number of hid class descrptors that follow (1)      ==24
         0x22, //report descriptor type (0x22 == HID)                ==25
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==26,27
   //endpoint descriptor 1
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==28
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==29
         0x81, //endpoint number and direction (0x81 = EP1 IN)       ==30
         0x03, //transfer type supported (0x03 is interrupt)         ==31
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported                  ==32,33
         250,  //polling interval, in ms.  (cant be smaller than 10)      ==34
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==35
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==36
         0x01, //endpoint number and direction (0x01 = EP1 OUT)      ==37
         0x03, //transfer type supported (0x03 is interrupt)         ==38
         USB_EP1_RX_SIZE,0x00, //maximum packet size supported                  ==39,40
         10 //polling interval, in ms.  (cant be smaller than 10)    ==41
   //endpoint descriptor 2
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==42
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)     ==43
         0x82, //endpoint number and direction (0x82 = EP2 IN)           ==44
         0x03, //transfer type supported (0x03 is interrupt)             ==45
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported           ==46,47
         250,  //polling interval, in ms.  (cant be smaller than 10)     ==48
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==49
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)     ==50
         0x02, //endpoint number and direction (0x02 = EP2 OUT)      ==51
         0x03, //transfer type supported (0x03 is interrupt)         ==52
         USB_EP1_RX_SIZE,0x00, //maximum packet size supported                  ==53,54
         250 //polling interval, in ms.  (cant be smaller than 10)    ==55
