Out of ROM, A segment or the program is too large MAIN ??
johnger
PostPosted: Sat Jan 09, 2010 8:24 am     Reply with quote
Sad Sad Sad
I have a problem
before me program is good:
Memory usage: ROM=54% RAM=15% - 21%
0 Errors, 3 Warnings.
and add intruccion litter while funcion and :
Executing: "C:\Archivos de programa\PICC\Ccsc.exe" +FM "EMPQ.C" +DF +LN +T +A +M -Z +Y=9 +EA
>>> Warning 203 "D:\JGGG\CCS_temp\JEB\EMPQ\EMPQ.C" Line 183(1,1): Condition always TRUE intb
>>> Warning 216 "D:\JGGG\CCS_temp\JEB\EMPQ\EMPQ.C" Line 1002(0,1): Interrupts disabled during call to prevent re-entrancy: (@delay_ms1)
>>> Warning 202 "D:\JGGG\CCS_temp\JEB\EMPQ\EMPQ_def.h" Line 112(4,13): Variable never used: pastillas
*** Error 71 "D:\JGGG\CCS_temp\JEB\EMPQ\EMPQ.C" Line 1002(0,1): Out of ROM, A segment or the program is too large MAIN
Seg 00800-00FFF, 0665 left, need 0948
Seg 01000-017FF, 0800 left, need 0948
Seg 01800-01FFF, 0800 left, need 0948
Seg 00000-00003, 0000 left, need 0948
Seg 00004-00049, 0000 left, need 0948
Seg 0004A-007FF, 0033 left, need 0948
1 Errors, 3 Warnings.
Halting build on first failure as requested.
why??? i do'n know
please help me
Humberto
PostPosted: Sat Jan 09, 2010 9:36 am     Reply with quote
The compiler spot the right clue.
Suggestions:
1) Go back to your last compilable version.
2) Open and check the generated program .sta
Then read this in order to proceed.
http://www.ccsinfo.com/faq.php?page=out_of_ram
Regards,
Humberto
johnger
Thank you , but
PostPosted: Sat Jan 09, 2010 10:35 am     Reply with quote
Do you speak spanish?
I am from Colombia.
I test the registers .sta
but I see a lot memory free.
 Segment     Used  Free
00000-00003     4  0
00004-00049    70  0
0004A-007FF  1917  57
00800-00FFF   410  1638
01000-017FF  1778  270
01800-01FFF     0  2048
Humberto
PostPosted: Sun Jan 10, 2010 6:22 am     Reply with quote
The "OUT OF ROM" error message do not refer to the whole memory available in you
MCU, it should be understood like:
"FUNCTION SIZE BIGGER THAN THE ALLOWABLE SEGMENT OF MEMORY"
Yes I speak spanish but we must accept the rules of the board, if you need further
help drop me a line using the private message option.
Saludos,
Humberto
