Switch SPI Mode PCD
Michael Starkloff
Switch SPI Mode PCD
PostPosted: Tue Jan 05, 2010 4:46 am     Reply with quote
How can I change the SPI_Mode during MCU is running? Some Devices work with SPI_Mode_0 and some other Devices with SPI_Mode_1. I cannot change the first selected SPI_Mode.
PostPosted: Tue Jan 05, 2010 8:07 am     Reply with quote
It's been said, that you have to disable the SPI interface before changing the mode or speed, but I didn't try.
Michael Starkloff
PostPosted: Tue Jan 05, 2010 8:18 am     Reply with quote
I tried this (setup_spi(SPI_SS_DISABLED) or setup_spi(0x8000)), but with no success. Is there another possibility to switch off the SPI interface and then change to another SPI Mode?
In older projects I used another PIC (PIC16F877) with the PCM Compiler there wasn't a problem by changing the SPI Mode.
