kukac24
I2C works with internal osc? |
Posted: Mon Jan 25, 2010 2:33 pm |
Could somebody tell me, that the HW I2C works with internal oscillator?
I try it with 18f4520 and 18f2520 and a DS1307. Pull ups are on the each lines, everything is ok by the HW side.
Thank you in advance! |
Posted: Mon Jan 25, 2010 3:02 pm |
It should work. Just try it. |
Posted: Mon Jan 25, 2010 3:29 pm |
I2C is full asynchronous and not relying any kind of timing accuracy. Why it shouldn't work? |
bkamen
Posted: Tue Jan 26, 2010 1:23 am |
FvM wrote: | I2C is full asynchronous and not relying any kind of timing accuracy. Why it shouldn't work? |
Async??
What's SCL for then?
:D _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
Posted: Tue Jan 26, 2010 3:00 am |
Yes, he just got the 'a' in by mistake.
I2C, is technically a 'data/strobe synchronous' transfer. It is timed by the SCL line, and couldn't at heart 'give a hoot' about the stability of the clock (within some limits set by individual devices).
It'll run quite happily off chips using basic RC oscillators far worse than the internal RC oscllator.
