Generating Compiler Messages
seme
PostPosted: Thu Aug 02, 2007 1:50 am     Reply with quote
Just like with the messg directive in MPASM I need to generate
warnings with CCS-C. Those warnings should be printed to the
screen for a feedback to the user. For example "Warning:
Debug Mode enabled".
The #error directive causes the compiler to abort, in an #asm
block messg is not recognized, printf only works for RS232.
Is there any possibility to make the compiler print a warning
message to the screen?
Thanks a lot for your input!
Cheers,
seme
PostPosted: Thu Feb 12, 2009 6:59 am     Reply with quote
Hi
Try the pre-processor directive
 #error/warning  Text
cheers Simon
portscanner
Cant get #warning to generate a warning
PostPosted: Sat Jan 02, 2010 8:52 am     Reply with quote
here is my test code:
#include <18F87J60.h>
#fuses NOWDT,STVREN,XINST,NOPROTECT,H4_SW,FCMEN,IESO,WDT32768,ETHLED
#use delay(clock=25000000,external)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,enable=PIN_C0)
#IGNORE_WARNINGS NONE
#WARNING will robinson
When compiled with the command:
ccsc +FH x.C
I get:
CCS PCH C Compiler
Registered to: portscanner ,
in /home/portscanner/development/
Compiling:  x.C
     Linking
     Writing x.hex
     Writing x.sym
     Writing x.lst
     Writing x.cod
     Writing x.pjt
Memory usage:
          ROM=0%
      RAM=0% - 0%
Files: 2,  Statements: 0,  Time: 1 Sec,  Lines: 461
0 Errors,  0 Warnings,  Time: 1 Seconds
No Errors   /home/delingch/development/DigilightII/2.03a/x.PJT
      0 Errors,  0 Warnings.
I am running PCH compiler version 4.101;7/1/2009 on Linux
Any suggestions?
bkamen
PostPosted: Sat Jan 02, 2010 1:15 pm     Reply with quote
I use #warning in code all the time with the windows compiler.
I've never used the #ignore_warnings though. Try turning that off just to see.
If it works then, you have maybe a bug..
I don't have the Linux Compiler to check againsts.
-Ben
portscanner
PostPosted: Sat Jan 02, 2010 2:01 pm     Reply with quote
There is no difference with or without the #ignore_warnings
Looks like a bug in the Linux version
PostPosted: Sun Jan 03, 2010 1:11 pm     Reply with quote
#warning has never worked in the command-line compilers.
It doesn't display anything in the Output Window in MPLAB.
I emailed CCS about this back in October 2008, for vs. 4.081.
(It still doesn't work in vs. 4.104).
They responded with an ID number for the bug, but never did
anything about it. I sent them a new email just now to remind
them about it.
