Software UART not working |
Posted: Fri Jan 01, 2010 1:46 pm |
I am trying to make a serial link between two MCs, but I failed.
TX side
#include<16f877a.h>
#use delay(clock=20m)
#fuses nowdt,hs
#use rs232(baud=4800, bits=8, parity=E, stop=1, xmit=PIN_A0, rcv=PIN_A1, stream=COM_a, ERRORS)
int data;
while(true)
fputc(0x02,com_A);
Rx Side
#include <18F2550.h>
#include<lcd420.c>
#use rs232(baud=4800, bits=8, parity=E, stop=1, xmit=PIN_A0, rcv=PIN_A1, stream=com_a, ERRORS) // For communicating with other PIC
#use rs232(baud=4800, bits=8, parity=E, stop=1, xmit=PIN_A2, rcv=PIN_A3, stream=com_b, ERRORS) //To computer, currently not using
int d1;
lcd_init();
printf(lcd_putc,"\fWelcome");
delay_ms(2000);
d1= fgetc(com_A);
printf(lcd_putc,"\fd1=%x",d1);
I am getting some garbage values....like 20,84,2
Please help me.... |
Posted: Fri Jan 01, 2010 3:41 pm |
You will....
The software UART, has to be _sitting waiting_ for an incoming character.
In your case, the receiving PIC, paues for 2.2+ seconds, before even starting to try to receive. It will see the first _falling_ edge on the serial line after this point, as the start of the character, so will receive garbage, since it will be in the middle of a continuous stream of characters. Even if by sheer chance, it happens to start at the right point for one character, your code then pauses for 0.1seconds (plus the time to write to the LCD), so another 2.9 characters will have already been missed, and the code will start looking inside another character, and again receive garbage.
Do a search here. There are some possible solutions (using a hardware interrupt to actually trigger character reception, or in the past I have posted a 'core' to a timer based software UART), but what you are trying to do, just won't work with the software UART as it stands.
