dev39 Guest
Pointer to function |
Posted: Thu Dec 31, 2009 6:50 am |
I tried to create a pointer to function within a structure but it gives me error. Simple pointer to function (out side structure compiles file). Can someone let me know whats going wrong here? The compiler version I am using is 4.0
#include <18F46K20.h>
typedef int err_t;
typedef err_t (* _ptr_to_fn_)();
err_t test(){
return 0;
struct l2cap_pcb
_ptr_to_fn_ fn;
struct l2cap_pcb *pcb;
_ptr_to_fn_ tmp_fn;
*tmp_fn=test;
(*tmp_fn)(); //this compiles fine
(*pcb->fn)=test;
(*pcb->fn)();//this gives error
Thanks |
dyeatman
Posted: Thu Dec 31, 2009 7:42 am |
4.0 is not the correct compiler version.
The version number is in the format of 4.xxx (3 digits after the decimal point). _________________ Google and Forum Search are some of your best tools!!!! |
dev39 Guest
Pointer to function- compiler version is 4.078 |
Posted: Thu Dec 31, 2009 7:53 am |
The compiler version is 4.081 |
dev39 Guest
Pointer to function- compiler version is 4.081 |
Posted: Thu Dec 31, 2009 7:54 am |
Sorry for the confusion in last post
Posted: Thu Dec 31, 2009 3:49 pm |
I'm more worried about the indirection levels here.
pcb, is declared as a pointer to a structure containing a pointer to a function, but at no point is this pointer made to point to a physical structure. It could be pointing anywhere.....
dev39 Guest
Thanks guys |
Posted: Thu Dec 31, 2009 11:42 pm |
Thanks guys for useful responses. |
