memoally
memory problem |
Posted: Sun Mar 07, 2010 4:59 pm |
Hi everyone.
I have a code for a work. But when I compile it, I got:
Quote: |
''out of rom,a segment or the program is too large''
seg 00004-007ff,0522 left,need 0700
seg 00800-00fff,0800 left,need 0812
seg 01000-017ff,0800 left,need 0812
seg 01800-01fff,0000 left,need 0812
seg 00004-007ff,0522 left,need 0812
When I comment out one or two 'write_eeprom(...)' statements, I get 34% rom 5% ram usage. Only a few line needs 55-60% rom ???
By the way, I use 16f876 pic with 8 mhz crystal osc. My code is about 500 lines, so I did not post it here. But if anyone wants to examine it to find the problem, I can.
How can I overcome this problem? Any advice? _________________ compiler version: 4.105
pic: 16f876
clock frequency: 4MHz |
Posted: Sun Mar 07, 2010 6:12 pm |
Have you tried the search option of this forum?
When you have tried this option and still have problems then come back and post your compiler version. |
memoally
Posted: Mon Mar 08, 2010 4:49 pm |
First of all thank you ckielstra.
Yes I tried, but I can't resolve the problem. My compiler version is 4.068.
I thought it might be helpful to find the problem. Here is my code.
Sorry for the length
Code: | #include <16F876.h>
#device adc=8
#FUSES RC //Resistor/Capacitor Osc with CLKOUT
#FUSES PROTECT //Code protected from reads
#FUSES NODEBUG
#use delay(clock=8000000)
#define use_portb_lcd TRUE // b portundan veri alincak
#include <lcd.c>
int device=0; //baslangic olarak 1.cihaz secili
int device_position=0; //baslangic olarak yuksek konum secili
float voltage; //ra1 bacagindaki analog input
int digital; //ra1 bacagindaki digital input
int battery_digital; //pilin doluluk oraninin dijital karsiligi,pin a2 den okunan analog voltajin digital karsiligi
float battery_voltage; //pin a2 den okunan analog voltaj degeri,pilin bataryasi
setup_adc_ports(AN0_AN1_AN3);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,255,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(0);
set_tris_a(0xff); //a portu tamamen giris
set_tris_b(0x00); //b portu tamamen cikis
set_tris_c(0xf0); //c7 c6 c5 c4 giris c3 c2 c1 c0 cikis (cikisler pwm icin,girisler rx ve tx icin)
lcd_init(); //lcd yi initialize et
printf(lcd_putc,"\fmerhaba"); // baslangic noktasini gormek icin meraba yaz
delay_ms(750);
device=read_eeprom(0); //hangi cihazda kalindigini burasi tutucak
//device_position=read_eeprom(1); //hangi konumda oldugumuzu burasi tutucak
while(1) //sonsuz dongu,program bu dongu icinde calisacak
//////////////////// cihaz secimi ve ona gore duty ayari ///////////////////
if (!input(pin_a2))
delay_ms(100); // Butona basilinca meydana gelen arkin etkisini önlemek için verilen gecikme
device=device+1; // cihaz degeri 1 arttiriliyor
if (device==10) // cihaz degeri test ediliyor.i degeri 10 olunca sifirlaniyor.
device=0; // cihaz 10 u gecince,cihaz degeri sifirlaniyor
switch(device)
case 0:
write_eeprom(0,device);
lcd_gotoxy(1,1);
printf(lcd_putc,"M929 ");
if (!input(pin_a4))
device_position=device_position+1; // cihaz degeri 1 arttiriliyor
if (device_position==2) // cihaz degeri test ediliyor.i degeri 10 olunca sifirlaniyor.
device_position=0; // pozisyon 2 olunca,degeri sifirlaniyor
switch(device_position)
case 0://write_eeprom(1,device_position);
set_pwm1_duty(60);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-4/1");
case 1://write_eeprom(1,device_position);
set_pwm1_duty(10);
lcd_gotoxy(7,1);
printf(lcd_putc,"d-2/4");
case 1:
lcd_gotoxy(1,1);
printf(lcd_putc,"M929A ");
if (!input(pin_a4))
device_position=0; // cihaz degeri sifirlaniyor
set_pwm1_duty(65);
lcd_gotoxy(7,1);
set_pwm1_duty(15);
lcd_gotoxy(7,1);
case 2:
lcd_gotoxy(1,1);
printf(lcd_putc,"M978 ");
if (!input(pin_a4))
set_pwm1_duty(70);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-4/4");
set_pwm1_duty(20);
lcd_gotoxy(7,1);
printf(lcd_putc,"d-N/A");
case 3:
lcd_gotoxy(1,1);
printf(lcd_putc,"M978A ");
if (!input(pin_a4))
set_pwm1_duty(75);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-4/5");
set_pwm1_duty(25);
lcd_gotoxy(7,1);
printf(lcd_putc,"d-2/3");
case 4:
lcd_gotoxy(1,1);
printf(lcd_putc,"M983 ");
if (!input(pin_a4))
set_pwm1_duty(80);
lcd_gotoxy(7,1);
set_pwm1_duty(30);
lcd_gotoxy(7,1);
case 5:
lcd_gotoxy(1,1);
printf(lcd_putc,"M983A ");
if (!input(pin_a4))
set_pwm1_duty(85);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-4/2");
set_pwm1_duty(35);
lcd_gotoxy(7,1);
printf(lcd_putc,"d-2/6");
case 6:
lcd_gotoxy(1,1);
printf(lcd_putc,"M993 ");
if (!input(pin_a4))
set_pwm1_duty(90);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-5/6");
set_pwm1_duty(40);
lcd_gotoxy(7,1);
case 7:
lcd_gotoxy(1,1);
printf(lcd_putc,"M993A ");
if (!input(pin_a4))
set_pwm1_duty(95);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-6/1");
set_pwm1_duty(45);
lcd_gotoxy(7,1);
printf(lcd_putc,"d-2/1");
case 8:
lcd_gotoxy(1,1);
printf(lcd_putc,"M995 ");
if (!input(pin_a4))
set_pwm1_duty(100);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-6/2");
set_pwm1_duty(50);
lcd_gotoxy(7,1);
case 9:
lcd_gotoxy(1,1);
printf(lcd_putc,"M995A ");
if (!input(pin_a4))
set_pwm1_duty(105);
lcd_gotoxy(7,1);
printf(lcd_putc,"y-6/3");
set_pwm1_duty(55);
lcd_gotoxy(7,1);
} // switch in sonu
/////////////////pil durumu olcumu ////////////////////
set_adc_channel(3); //3 nolu analog pin adc cevriminde kullanilacak
delay_us(20);
battery_digital=read_adc(); //analog veriyi oku,digital olarak digital degiskeninde sakla
battery_voltage=battery_digital*0.0351563; // 9/256=0.0351563
if(battery_voltage>7.5 && battery_voltage<=9)
lcd_gotoxy(1,2);
printf(lcd_putc,"B:|||||");
else if(battery_voltage>6 && battery_voltage<=7.5)
lcd_gotoxy(1,2);
printf(lcd_putc,"B:|||| ");
else if(battery_voltage>=4 && battery_voltage<=6)
lcd_gotoxy(1,2);
printf(lcd_putc,"B:||| ");
else if(battery_voltage>=2 && battery_voltage<=4)
lcd_gotoxy(1,2);
printf(lcd_putc,"B:|| ");
else if(battery_voltage>=0 && battery_voltage<=2)
lcd_gotoxy(1,2);
printf(lcd_putc,"B:| ");
///////////////////// kalibrasyon ledi ile ilgili kisim //////////////////////
set_adc_channel(1); //1 nolu analog pin adc cevriminde kullanilacak
delay_us(20);
digital=read_adc(); //analog veriyi oku,digital olarak digital_a1 degiskeninde sakla
voltage=digital*0.0195313; // 5/256=0.0195313
if(voltage<2.7) //IR ledini yakmak icin gerekli kisim
printf(lcd_putc,"\fkal!");
set_pwm1_duty(0);
while(1); // sonsuz dongu,kalibrasyon ledi surekli yansin...
else;
} //while in sonu
} //main in sonu
It is very long I know. Sorry for that but the code is actually simple.
It does same thing for ten different devices with a switch statement.
Only the duty cycle values are different. My problem is that if you
examine the code you will see 20 "write_eeprom(1,device_position)"
statements, all of them inside the super loop, fragmented in switch
statement. And a device_position=read_eeprom(1) statement just above
the super loop.
All of them are commented out initially. When I remove the first 5 "//" 's,
there is no problem (%34 rom %5 ram usage), but if I add the 6th or
any one of the remainings from 6th to 21th (1 read + 20 write), I get this
error. I could not find how to resolve the problem. Actually I want to use
also receive data enable interrupt to set up initial duty cycles by serial
port, but when I add this again I had the rom problem again. Does a PIC
add subroutines just below the call statement, when it is to be written on
program memory? Or is there a problem with my compiler version
maybe? _________________ compiler version: 4.105
pic: 16f876
rnielsen
Posted: Tue Mar 09, 2010 9:46 am |
I compiled your code, as posted, with version 3.249 with no issues. My results are:
ROM used: 2549 words (31%)
Largest free fragment is 2048
RAM used: 19 (11%) at main() level
31 (18%) worst case
Stack: 4 locations
It might be a bug with your version since this compiles fine with an older one.
Ronald |
languer
Posted: Tue Mar 09, 2010 10:56 am |
Uncommenting all the write_eeprom statements, I got the same results (as the original poster) for both 3.249 and 4.104 (i.e. not enough ROM space).
Replacing the write_eeprom with the my_write_eeprom wrapper functions by ckielstra, code compile and with 24% ROM usage. |
memoally
Posted: Tue Mar 09, 2010 4:51 pm |
I replaced all write_eeprom and read_eeprom statements with ckielstra's
functions and remove all '' // '' 's. Now I get %31 usage of rom
Thank you guys. But I wonder why languer, rnielsen and I have different results.
Should not I trust ccs c program??? _________________ compiler version: 4.105
pic: 16f876
Posted: Tue Mar 09, 2010 5:00 pm |
You are testing it with a different compiler version than rnielsen and
languer. All versions are different. |
memoally
Posted: Sat Mar 13, 2010 4:50 am |
Thank you pcm programmer for your reply. I changed my code a little bit, but there is a problem with eeprom. I want the device to work where it was closed. I mean think about you power off the pic when the device 4 is selected, and when you power up pic it should start from device 4 not device 1.
I added some my_eeprom_read and my_eeprom_write codes but it did not work for the real network, whereas it works for a Proteus simulation. Also I managed to insert the RDA_interrupt but it did not work for the purpose. Could anyone correct my wrongs or mistakes?
By the way, I will try to tell what the whole code does. It does:
-Battery measurement
-Calibration control (only measures a pin - whether it is below 2.7 volts)
- Recognizes 10 different devices and generates 2 different duty cycles for each device, one is low duty cycle and other is high duty cycle.
There are 2 buttons. One is for choosing device (10 device exist) and other is for choosing the position, duty high or duty low positions. And all of the stuff will be displayed on a 8x2 lcd display.
I initially put this duty cycles into eeprom and program reads it. I am also supposed to change this initial duty cycles via serial port. In RDA_interrupt service routine I tried to read the data first and update it according to the character which is entered from the keyboard. But I could not make this.
So there are two problems now:
1- I could not manage eeprom thing,pic stays printf(lcd_putc,"Merhaba") part, I could not get into devices.
2- Serial port part, which is to find the data position on eeprom, read it, update it and write eeprom permanently. I mean when you power up the pic, it should read the updated duty cycles.
Here is my code. Again sorry for the length:
Quote: |
#include <16F876.h>
#device adc=8
#FUSES XT //Resistor/Capacitor Osc with CLKOUT
#FUSES NODEBUG
#include <lcd.c> // lcd.c dosyasini programa dahil et
/////degisken tanimlamalari///////////
int duty_high_cycles[10]={221,100,92,115,100,106,109,98,91,85}; //yuksek konumlarin duty cycle lari
int duty_low_cycles[10]={10,30,26,2,5,16,23,21,36,31}; //dusuk konumlarin duty cycle lari
int eeprom_adress;
//char char_input='0';
//int temp;
/////fonksiyon tanimlamalari////
int8 my_read_eeprom(int8 Address) //e2prom dan veri okuyan fonksiyon
return read_eeprom(Address);
void my_write_eeprom(int8 Address, int8 Value) //e2prom a veri yazan fonksiyon
write_eeprom(Address, Value);
void calibration_check(void) //kalibrasyon ledinin yanip yanmayacagini kontrol eden fonksiyon
delay_us(20);
printf(lcd_putc,"\fKalib!");
set_pwm1_duty(0);
else;
void battery_check(void) ///// pil durumunu olcen fonksiyon
delay_us(20);
battery_voltage=battery_digital*0.0195313; // 5/256=0.0195313
if(battery_voltage>4 && battery_voltage<=5)
lcd_gotoxy(6,2);
printf(lcd_putc,"B:5");
else if(battery_voltage>3 && battery_voltage<=4)
lcd_gotoxy(6,2);
printf(lcd_putc,"B:4");
else if(battery_voltage>=2 && battery_voltage<=3)
lcd_gotoxy(6,2);
printf(lcd_putc,"B:3");
else if(battery_voltage>=1 && battery_voltage<=2)
lcd_gotoxy(6,2);
printf(lcd_putc,"B:2");
else if(battery_voltage>=0 && battery_voltage<=1)
lcd_gotoxy(6,2);
printf(lcd_putc,"B:1");
///////kesme service routines////////
#int_RDA
void serialport_incoming_char_interrupt(void) //klavyeden rs232 uzerinden girilen karakterlerin olusturdugu kesme fonksiyonu
char_input=getc(); //karakteri al ve girdi degiskenine aktar
delay_ms(100); //karakteri aldiktan sonra buton arkini onlemek icin bir sure bekle
if(char_input=='1') //girilen karakter '1' ise
temp=duty_high_cycles[device]; //duty cycle'i temp degiskenine aktar
temp=temp+10; //temp i 5 artir
duty_high_cycles[device]=temp; //temp i array icine geri koy
printf(lcd_putc,"\fduty:%d",duty_high_cycles[device]); //lcd de duty cycle goster
my_write_eeprom(device,duty_high_cycles[device]);
else if(char_input=='2') //girilen karakter '2' ise
temp=temp-10; //temp i 5 artir
else if(char_input=='4') //girilen karakter '4' ise
temp=duty_low_cycles[device]; //duty cycle'i temp degiskenine aktar
duty_low_cycles[device]=temp; //temp i array icine geri koy
printf(lcd_putc,"\fduty:%d",duty_low_cycles[device]); //lcd de duty cycle goster
my_write_eeprom(device+10,duty_low_cycles[device]);
else if(char_input=='5') //girilen karakter '5' ise
else;
//char_input='0';
/////////////////////// ana program //////////////////////////////
//enable_interrupts(INT_RDA);
//enable_interrupts(GLOBAL);
set_pwm1_duty(0);
lcd_gotoxy(1,1);
printf(lcd_putc,"\fMerhaba"); // baslangic noktasini gormek icin meraba yaz
delay_ms(1200);
device=my_read_eeprom(20); //hangi cihazda kalindigini burasi tutucak
device_position=my_read_eeprom(21); //hangi konumda oldugumuzu burasi tutucak
for(eeprom_adress=0;eeprom_adress<9;eeprom_adress++) //yuksek cycle degerleri 2-12. adreslere yaziliyor
my_write_eeprom(eeprom_adress,duty_high_cycles[eeprom_adress]);
for(eeprom_adress=10;eeprom_adress<20;eeprom_adress++) //dusuk cycle degerleri 12-21. adreslere yaziliyor
my_write_eeprom(eeprom_adress,duty_low_cycles[eeprom_adress]);
if (!input(pin_a2))
delay_ms(25); // Butona basilinca meydana gelen arkin etkisini önlemek için verilen gecikme
while(!input(pin_a2)); //butondan el cekilene kadar
switch(device)
case 0:
my_write_eeprom(20,device);
lcd_gotoxy(1,1);
if (!input(pin_a4))
while(!input(pin_a4)); //butondan el cekilene kadar
case 0:my_write_eeprom(21,device_position);
set_pwm1_duty(duty_high_cycles[device]);
lcd_gotoxy(1,2);
printf(lcd_putc,"Y4/1");
case 1:my_write_eeprom(21,device_position);
set_pwm1_duty(duty_low_cycles[device]);
lcd_gotoxy(1,2);
printf(lcd_putc,"D2/4");
case 1:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
lcd_gotoxy(1,2);
case 2:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y4/4");
lcd_gotoxy(1,2);
printf(lcd_putc,"DN/A");
case 3:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y4/5");
lcd_gotoxy(1,2);
printf(lcd_putc,"D2/3");
case 4:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
lcd_gotoxy(1,2);
case 5:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y4/2");
lcd_gotoxy(1,2);
printf(lcd_putc,"D2/6");
case 6:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y5/6");
lcd_gotoxy(1,2);
case 7:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y6/1");
lcd_gotoxy(1,2);
printf(lcd_putc,"D2/1");
case 8:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y6/2");
lcd_gotoxy(1,2);
case 9:
lcd_gotoxy(1,1);
if (!input(pin_a4))
lcd_gotoxy(1,2);
printf(lcd_putc,"Y6/3");
lcd_gotoxy(1,2);
} // switch in sonu
battery_check();
calibration_check();
} //while in sonu
} //main in sonu |
pic: 16f876
