set_timer() and delay
BBN
PostPosted: Sun Dec 27, 2009 11:23 pm     Reply with quote
Hi.
Just quick question.
does the function set_timerX(); include the delay for the time it takes to record on the timer? or do I have to put in delay separately?
Rohit de Sa
PostPosted: Sun Dec 27, 2009 11:47 pm     Reply with quote
What exactly do you mean by this? The timer is a variable in RAM. RAM is not like EEPROM; writes to RAM are almost instantaneous, requiring only a few nanoseconds.
There is one thing however - once you write to timer0, it will not increment for two clock cycles. So you'd need to put an 'adjusted' value into timer0 when you use 'set_timer0();'.
Rohit
