Complex struct...
Complex struct...
PostPosted: Sun Dec 20, 2009 1:46 am     Reply with quote
Hello
Is there any known problem using complex struct in 4.093?
Just a ex. not production code...
struct {
 struct {int18 a; int8 b; int1 c;}L;
 struct {int18 a; int8 b; int1 c;}R;
 struct {int18 a; int8 b; int1 c;}U;
 struct {int18 a; int8 b; int1 c;}D;
}Master;
PostPosted: Sun Dec 20, 2009 3:05 am     Reply with quote
Found this:
And I think it is frustration, _wakeup_ CCS! Waste time using this buggy thing.
#include "18F4550.h"
struct {
 struct {int8 a; int16 b; int1 c;}S1;
 struct {int8 a; int16 b; int1 c;}S2;
}Master;
void t1(){
 Master.S1.A=0x12; //Make wrong assign
 Master.S1.b=0x1234;
 Master.S1.c=1;
 Master.S2.A=0x13;//Make right assign
 Master.S2.b=0x1234;
 Master.S2.c=1;
void main(){
 t1();
.................... struct {
....................  struct {int8 a; int16 b; int1 c;}S1;
....................  struct {int8 a; int16 b; int1 c;}S2;
.................... }Master;
.................... void t1(){
....................  Master.S1.A=0x12;
0004:  MOVLW  12
0006:  MOVWF  Master
....................  Master.S1.b=0x1234; ERROR! Look at S2
0008:  MOVWF  Master+2
000A:  MOVLW  34
000C:  MOVWF  Master+1
....................  Master.S1.c=1;
000E:  BSF    Master+3.0
....................  Master.S2.A=0x13;
0010:  MOVLW  13
0012:  MOVWF  Master+4
....................  Master.S2.b=0x1234; RIGHT
0014:  MOVLW  12
0016:  MOVWF  Master+6
0018:  MOVLW  34
001A:  MOVWF  Master+5
....................  Master.S2.c=1;
001C:  BSF    Master+7.0
001E:  GOTO   0038 (RETURN)
PostPosted: Sun Dec 20, 2009 6:05 am     Reply with quote
The code shown is correct....
The point is in the first case, 'W' already contains '12', from the assign to S1.a, so the compiler saves an instruction, by not loading it again.
0004:  MOVLW  12
0006:  MOVWF  Master
0008:  MOVWF  Master+2 //Here 'W' already contains 12, so this is put
//into the LSB of Master.S1.b
000A:  MOVLW  34
There is nothing wrong with the assignment as shown. So the question is 'what are you seeing that is not working'?.
PostPosted: Sun Dec 20, 2009 8:46 am     Reply with quote
Hello and thanks for the explanation.
I'am real sorry CCS! I complain too early.
The real problem was the late time last night, the problem is now solved.
