Pic to PC interface
hisham.i
Pic to PC interface
PostPosted: Thu Oct 28, 2010 8:33 am     Reply with quote
am trying to make an interface between pc and pic16f877A, which allows me to switch a led on and off using a push button.
i made the gui in matlab and programed the bushbutton, and then i wrote the microcontroller program, but while i was simulating it nothing happens, i didn't recognize the problem.
this is the code
#include <16f877A.h>
#include <stdio.h>
#use delay(clock = 4MHZ)
main()
{ byte a;
setup_uart(9600);
output_low(PIN_B0);
output_low(PIN_B2);
a=getch();
if(a=="g")
{ output_high(PIN_B0);
{output_high(PIN_B2);
thanks for help
Wayne_
PostPosted: Thu Oct 28, 2010 8:44 am     Reply with quote
First problem:-
if(a=="g")
Double qoutes ("") are used to indicate the start and end of a string for the compiler. a is defined as a byte (single char).
Try changing your condition to
if(a=='g')
Note the use of single quotes, these are used to indicate a single char to the compiler.
I am assuming your matlab code sends the char 'g' when you press the button!
