Explorer16 demo board and USB
Confused
PostPosted: Tue Dec 15, 2009 3:45 am     Reply with quote
Did someone try to test the ex_usb_hid.c on the explorer16 db?
Each time when I plug in the USB cable from PC I get message that the cable is attached but not enumerated.
PostPosted: Tue Dec 15, 2009 5:32 am     Reply with quote
If you had checked the forum for recent posts on USB & PIC24, you would know...
See e.g. http://www.ccsinfo.com/forum/viewtopic.php?t=40905
Confused
PostPosted: Tue Dec 15, 2009 7:30 am     Reply with quote
I'm using 4.099 so it can not be compiler error.
The software pullup didn't change the situation.
PostPosted: Tue Dec 15, 2009 10:26 am     Reply with quote
To make the problem understandable, you should post your complete Explorer 16 hardware configuration.
