mgillespie
| Compiling from the commandline / using external editor. |
Posted: Tue Dec 15, 2009 4:20 am |
The included IDE is so horrendously bad, it's quite simply unbelievable. The number of problems, and the lack of any progress fixing them means I really need to throw the IDE in the bin and use a proper editor and commandline compile. Is this possible? Anyone worked out how?
I want to use my editor of choice (PSPAD): http://www.pspad.com/
Some of my IDE problems:
Impossible to use on Windows7, catastrophic errors, GUI bugs, crashing.
Truncated error and information dialogs on all OS (particularly bad if your change management system /project complexity makes you use quite long path names).
Abysmal Find, worse when using keyboard shortcuts, no highlight/list all. |
mgillespie
Posted: Tue Dec 15, 2009 5:08 am |
OK, got a batch file working, so I never have to touch the CCS IDE again. However I can't seem to find if the compiler uses errorlevels on the return to determine if the code compiled correctly. I want to be more intelligent about my post compile handling.
@echo off
rem CSSC commandline build script, because the IDE is so horrid (I hope their compiler skills are better than their IDE writing skills!)
c:\Progra~1\PICC\Ccsc.exe -T -A -D -L -M -J +FH +DF ..\Source\main.c
type ..\source\main.err
del ..\source\main.err
del ..\source\main.esym
attrib -r ..\Deliverables\MyRealName.hex
attrib -r ..\Deliverables\MyRealName.cof
move ..\source\main.hex ..\Deliverables\MyRealName.hex
move ..\source\main.cof ..\Deliverables\MyRealName.cof
Can I also prevent the esym file being created? I don't need or want it. |
