After spending one whole day to figure out what could be the problem, and after thinking "Ok i'm doing something really stupid here ", i found the problem.
You guess... PCD compiler error.
I removed the 4.100 version and installed the 4.099.
All is working like a charm.
I could write some additional lines on this but i'm still CCS fan so i will skip this part. Nevertheless i'm still really pissed off.
Posted: Sat Dec 12, 2009 12:50 pm
Why post the conclusion in a new thread ? Now the existing thread
doesn't have the final conclusion in it.
Always put the final post (that has the conclusion) at the end of the
existing thread on the problem. Then people can see the problem
and the solution.
When you make a post to the existing thread, the complete thread
will go to the top of the list on the forum. Everyone will see it.
