Program won't run after power is cycled
AllanG
PostPosted: Sun Dec 20, 2009 8:34 pm     Reply with quote
I'm new to CCS compilers and have encountered a strange problem
I can write a program with PCWH, load it with my PicKit2 programmer, and the program runs correctly. I'm using an 18f2320.
I'm using an external power supply, and if I cycle the power the PIC won't restart. It just sits there doing absolutely nothing.
I have the HEX file of another program that runs and power cycles correctly, so I know the hardware is OK.
Unfortunately, the working source code was in the programmer's thumb drive when he stormed out of the building 2 weeks ago, so I can't just copy the configuration bits and other information from the good program.
Anybody ever seen anything like this?
Thanks, Al
PostPosted: Sun Dec 20, 2009 9:06 pm     Reply with quote
You can read the PIC into MPLAB (using the Programmer / Read menu)
and then look at the Config bits ("fuses" in CCS) in the Configure /
Configuration Bits menu. You can look at the (ASM) code in the View /
Program Memory menu.
Make sure you select the correct PIC in the Configure / Select Device
menu, before you do this.
Also select your Pickit 2 programmer in the Programmer / Select
Programmer menu.
AllanG
PostPosted: Mon Dec 21, 2009 5:18 pm     Reply with quote
Thanks for the advice, PCM programmer.
I'll give it a try.
Al
