Multiple interrupts
MiniMe
Multiple interrupts
PostPosted: Wed Dec 02, 2009 3:34 pm     Reply with quote
Can I use multiple same (same type) interrupts.
Briefly can I use more than 1 #INT_TIMER1 ?
For example my area of use is LCD menu subsection ( very separated function) To check inputs frequently. Every time timer overflows.
How ?
Any example you can point out ?
If no ...
Will better programming fix a need to use multiple functions that act very a like. Any experience ? Points of view ?
Thank you in advance !
PostPosted: Wed Dec 02, 2009 3:47 pm     Reply with quote
You cannot have more than one instance of a particular timer. However, in my case I use a single timer that fires every 1ms or every 10ms as a master clock and service sub procedures at pre-selected time intervals.
For example:
Using a timer that has been set up for a 1ms timeout. Increment a set of counter variables in the ISR (one for each process you want to monitor). When a particular counter reaches the selected count for servicing a function (i.e. scan user input buttons every 8ms) set a flag for that function, reset the counter variable then exit the ISR and and service the flag in Main. This actually creates a crude form of RTOS.
MiniMe
PostPosted: Thu Dec 03, 2009 2:00 am     Reply with quote
Thank you !
Your reply helped me much !
There's a small example code.
#int_RTCC
RTCC_isr()
    //Before timer counter register was 0.
    set_timer0(64); // RTCC and TIMER0 - same thing, different name.
    //Now timer counter register is 64 - less time to overflow.
    count++;  //global variable
    if(count==10) {
    count = 11;
    //rest of code 1
        if(count==20) {
        count = 0;
        //rest of code 2
PostPosted: Thu Dec 03, 2009 8:10 am     Reply with quote
You really don't want servicing routines inside the ISR. The rule is to keep
it as short as possible and get out of the ISR.
Below is a rough example I threw together. You will need to take into
account rollover of the 1ms counter variable but overall it should give you
an idea of what I am saying.
you need to define _1mscntr is an int16
you should to define all flags as boolean or int1
#INT_TIMER1
void Timer1_int() // 1ms timer
    set_timer1(TIMER1START);  // restart the timer for the next 1ms interval
    // count the 1ms intervals
    if (--_1mscntr < 1)
          _1mscntr = 1000;  // reset for one second
          // increment the seconds counter
            seconds++;
          // Set flag to Toggle heartbeat LED here
           HB=1;
        }  // if --1mscntr < 1
// ** end of timekeeping section
     if (__1mscntr = 12) // we want to set a flag to run task1 here
           task1flag=1;
     if (_1mscntr =  35) // we want to set a flag to run task2 here
           task2flag=1;
    if (Delay_Ctr > 0)
          Delay_Ctr--; // used to keep track of a delay somewhere
    if (Response_Timer > 0)
          Response_Timer--;
}  // end of Timer1 ISR
// start of main routine
while (1)
    // Heartbeat routine
        if (HB)
         { //  this heartbeat routine ensures the interrupt timer and
            //  main routine are working
              ( do something here to toggle a heartbeat LED)
           HB=0; // reset the flag for the next round
        if (response_timer==0)
               response();  // print response message to the display etc.
        if (TASK1FLAG)
            { // do something for task1
              TASK1FLAG=0; // and finally reset the flag
Sergeant82d
PostPosted: Sun Dec 06, 2009 9:36 pm     Reply with quote
Thanks dyeatman, for a great explanation - I have read of that technique, but your little demo code really clarified the concept for me.
mbradley
PostPosted: Tue Dec 08, 2009 11:39 am     Reply with quote
I have thrown a little task manager together for just such an item. I needed to do several things at intervals, and the code started to look sloppy, so I wrapped it all up in a qued task manager.
Basicaly, each function executes at specific intervals
I just have to define some parameters for each task.
  // set task parameter ( task id, how many tics)
  mqTaskSetTmr(TASKID_LEDBLINK, 1000000);
  mqTaskEnable(TASKID_LEDBLINK);
  mqTaskSetPri(TASKID_LEDBLINK, QTPRI_HIGHEST); // set highest priority
while(true)
  mqTaskManager()
    // tell it what function to execute per task id
    mqTaskFunction(TASKID_LEDBLINK, task_blink_led());
    mqTaskFunction(TASKID_COUNT, task_count());
The source is here, written in CCS C: http://www.mculabs.com/drivers/qtask.html
Michael Bradley
www.mculabs.com
Open Drivers and Projects
