CDC Help
CDC Help
PostPosted: Sun Dec 06, 2009 11:53 am     Reply with quote
I am using windows 7 and my virtual serial port driver is not working with windows 7....
Its urgent please help me...
PostPosted: Sun Dec 06, 2009 1:02 pm     Reply with quote
No one know how....
Very bad...Its tooooo bad..
bungee-
PostPosted: Sun Dec 06, 2009 4:50 pm     Reply with quote
Use vista driver. It works Wink
PostPosted: Sun Dec 06, 2009 6:32 pm     Reply with quote
No..I tried it but failed..
bungee-
PostPosted: Mon Dec 07, 2009 1:39 am     Reply with quote
Is your project running on some other platform? When I had problems with my project it was like the driver is wrong. But when I sorted out HW and SW problems on the project driver on Win 7 worked like a charm.
I have Windows 7 x32
PostPosted: Mon Dec 07, 2009 3:13 am     Reply with quote
The Vista driver certainly does work for W7 X32.
I'd suggest the same thing as for Vista itself, make sure that you put the driver into a separate location, and point the install at this, rather than pointing the install at the PICC drivers directory, which contains multiple drivers. In the case of Vista, this was 'necessary', or the OS saw the other drivers, and got confused.
PostPosted: Mon Dec 07, 2009 9:28 am     Reply with quote
Oh thats great it works man....
