PIC 18F87J50 and OSCTUNE register for USB settings [solved]
rvalor
PostPosted: Fri Dec 04, 2009 4:22 am     Reply with quote
Hello everybody¡¡
I'm working with the 18F66J50 and the 18F87J50 PIC micros.
I'm trying to configure the USB at 48MHz and I've done this:
I use 8Mhz crystal ------> I need to convert it to 4MHz so ---> #FUSES HS and #FUSES PLL2...
and I seen on this forum I need to manually set on the 96MHz PLL because this isn't done automatically (PIC18f4550 did it), so I used this code:
//Define a variable in the right place...
#BYTE OSCTUNE = 0xF9B
#BIT OSCTUNE_PLLEN = 0xF9B.6
//and in main() while initializing I done:
//OSCTUNE_PLLEN = 1;    // Enable PLL
But while debugging the value of the OSCTUNE register doesn't change...
I'm very confused and I need to use the USB pheripheral...
Can somebody help me???
Thank you in advance.
rvalor
Problem solved¡¡¡
PostPosted: Fri Dec 04, 2009 4:40 am     Reply with quote
Hello everybody,
I've solved the problem:
The correct fuse to configure the PLL is the
#FUSE H4_SW         //High speed osc with SW enabled 4x PLL
then
#FUSES PLL2                     //Divide By 2(8MHz oscillator input)
and in main() now I can pull-up the PLLEN bit.
Doing this, the PIC has been recognized by the PC inmediately.
