#ZERO_RAM side effects?
PostPosted: Thu Dec 03, 2009 2:44 pm     Reply with quote
Hi:
I'm using the #ZERO_RAM directive, and I am wondering if there are any side effects. In the code below, if I use it, my serial ISR does not work. Without the #ZERO-RAM directive, it does
-Jeff
#include <18F67J50.h>
#fuses HS,NOWDT,NOPROTECT
/** local definitions **/
char buffer[81];           // Where the serial data is stuffed
char buffer_pos=0;
/** default settings **/
//#ZERO_RAM   commented out it works
   enable_interrupts(INT_RDA);
   while (TRUE)
// Service things here
#int_RDA
void get_buffer(void)        // get the message from the GPS module
  output_toggle(PIN_E2);
  if(kbhit())                // check if uart filled
    buffer[buffer_pos]=getc();     // get info
    buffer_pos++;
    if(buffer[buffer_pos-1]==10)   // Linefeed as end of record
    //   if(log_flag) log_buffer(buffer_pos-1);
       //!! Put in a flag to see if read_buffer updated anything
       //SentenceID = read_buffer();   // Sentence ID tells us what sentence was read
       buffer_pos=0;
PostPosted: Thu Dec 03, 2009 2:59 pm     Reply with quote
What's your compiler version ? CCS has this note on their versions page:
4.014 A problem using ZERO_RAM and ICD=TRUE together on some PIC18 parts is fixed
PostPosted: Thu Dec 03, 2009 10:03 pm     Reply with quote
4.101
PostPosted: Fri Dec 04, 2009 3:26 am     Reply with quote
Add 'ERRORS' to your RS232 directive.
One possibility, is that ZERO_RAM, takes significant time during bootup. Without 'ERRORS', the UART will hang, if more than a couple of characters are received, and not handled. If you were running at a much higher baud rate, I'd say this was 'likely', but at 9600bps, each character takes a mSec, and though in computer terms clearing all the RAM memory takes a lot of cycles, I can't see it taking even remotely near this sort of time....
However the ERRORS directive, ought to _always_ be present when using the hardware RS232, unless you are providing similar code yourself, so it is worth trying.
